Removing Rear Seat?
I used SEARCH and found this for you:
From this thread: https://www.scionlife.com/forums/viewtopic.php?t=205029
Originally Posted by PureAzn
If you just pull up on it, you'll remove the rear cushion maybe, and most likely break your seat. To remove the rear seat safely and/or completely:
1. Fold the seats down
2. Locate and remove the 4 bolts in the lower corners of each half of the rear seats - this removes the tops of the seats. (** the larger half is tethered via seat belt so unless you want to remove the seat belt, this will not be coming out - I just put mine in the cargo area)
3. Open the 3 tabs in the plastic tray and remove the 3 bolts there
4. Remove the 4 bolts for the bar along the rear seat
5. Push/twist/slide/unhook the little stiff tether towards the middle of the seat cushion holding it to the rear bar
6. Remove the 2 rear bolts for the tray frame by *gently* lifting up the cushions to access the bolts.
At this point you have bare floor/carpet. To pull the tray off the frame, there are 5 light/small bolts you can just take off. If you wish to seperate the cusion from the tray, simply push in the tabs on the 2 clips holding the cushion to the frame.
That is to remove the whole rear seat, right?
I bought a set of Clazzio seat covers and tried installing it. The instructions said that you can just pull on the front cushion. It is not working =(
cionide is correct but also lets not forget this stuff. a member was nice enough to grab some of the PDF files
http://www.fsu-clan.com/scion/interior/
this is the main one i suggest if you going to mod grab the xb zip file from here
the person you might want to drop a thank you to for these is drjman.
Thanks for the link and help from both of you.
The problem I'm right now is below. I can't get the hooks to disengage! When I try pulling the cushion up as stated, it stays there. If I use too much force, the cushion seems to deform...
HotLavaDestiny
Feb 8, 2015 05:25 AM
carid
Jan 22, 2015 12:49 PM
