Scion XB 2010 Engine Rebuild Kit
Old Apr 2, 2025 | 09:54 PM
sven30's Avatar
Default Scion XB 2010 Engine Rebuild Kit
Hello all!
Which one of these engine rebuild kits is correct and the best one for a 2010 scion XB that will fix the issue with the piston ring defect and oil consumption? I don't know if I'm going to do this, but I have a guy that might be able to for a decent labor price.
https://www.carparts.com/details/Sci...DNJRRK932.html
https://www.carparts.com/details/Sci.../DNJEK932.html
https://www.carparts.com/details/Sci...DNJEK932M.html
https://www.carparts.com/details/Sci...EK932MVVT.html
Old Apr 3, 2025 | 05:29 PM
Greg S's Avatar
The last three will work for it but you really need to open the engine up first to see what needs replacing. Bare minimum for the repair is the pistons and rings as they had the design flaw. Past that it depends on what, if anything, else has worn due to the problem. If the bearings spun you may need more than all of these kits have as you might need to replace the crankshaft, or get it machined. If you need to machine any of the bearing surfaces then the generic bearing supplied in these kits probably won't work as you'll need thicker ones to take up the extra space from the machining. Basically open up the engine first then you can figure out what you need.
Rob32174
Jan 6, 2022 06:52 PM
toddsta
Apr 28, 2012 08:11 AM
Flyyota
Regional - Southeast
Feb 6, 2012 12:06 AM
kent55
Regional - Great Lakes: CHI Metro
Jul 7, 2010 11:38 PM
postman
13
Jun 30, 2009 02:57 AM
