Tire Pressure Monitor System
Does anyone know where to purchase OEM Tire pressure monitor system or one that works with the factory installed for the 2008 Scion xB? I need a Set of (4) for my winter tires. I called Toyota and they are asking $106.52 each ($426.08 for 4), which is way too much. If anyone has any information, please post. Thank You.
nope, not really going to find them for a decent price. either transfer the sensors tot he winter tires, or drive around durring winter with the (!) light on. also, even if you do get the sensors, i think you have to have the dealership program them to your car specifically anyway. pretty much a lose lose.
Re: Tire Pressure Monitor System
Try tirerack.com. I was just on there looking at wheels, and on one of the pages that popped up was info on the pressure monitors. I think it said $370 for the set, but they also stated that you acn use the ones already there. If you buy new, it said there is a way to program to work with your car in the owner's manual book.
I heard... not proven yet........ but rummooored... that if you just take ONE. one from your original set... & put it on your spare tire..... as long as it's in the vehicle.... it will fool the computer & leave your warning light OFF!.. just a rumor though...... sounds logical though.... jh
Since the TPMS can tell when 1 of 4 tires is under-inflated, it makes sense that having only 1 sensor present would trigger the TPMS alert. IMO, you'd have to install 4 sensors in the spare tire or re-program the TPMS to work with only 1 sensor, if possible.
it won't tell you which one, but it will keep telling you that it is only receiving feedback from one sensor and not four, therefore it will continue to tell you something is wrong.
not really sure why this is a big deal. i mean, you'll have one indicator light on the dash board telling you that it isn't getting any TPMS information. so long as you check your tirs once a week, you'll be fine. guess the TPMS in my tc using the wheel speed sensor spoils me since i don't have to ever worry about transfering sensors.
lol, one time my TPMS light went off, checked all my tires, they were all fine, i was at the dealership doing this, and they told me to check the spare, it could be the spare that is setting off the warning light. i laughed at them, explaining how it runs on the abs wheel speed sensor, not a separate pressure sensor in the valve stem of the tires.
okay...
here's the deal.. the car monitors ALL the sensors at once including the spare and will trip the light if any are low.
if you get new sensors.. it's a waste of money and regardless there is NO WAY that you can reprogram the car's ecu to accept the new sensors.
it requires a special Toyota scantool that is very expensive, and i doubt anyone outside of a dealership would own one.
heh.. even some dealerships i know have to borrow one from another dealership sometimes.
so as stated... it's a lose lose..
you need to transfer the sensors over... it's the best course of action... unless you want to drive with that light on.
actually... now that i think about it, i'm not so sure if the spare has one... i know alot of other toyota's do... but i'm unsure for the xB in particular..
you got me doubting myself.... oyyy..
i gotta check tomorrow...
The dealer has to program the tire pressure sensors if they are replaced or if one is damaged. There is a serial number on the sensor itself and that is the number that is programmed into the TPMS ecu.
The dealer has a special 6000.00 scan tool that does this.
You cannot use aftermarket tire pressure sensors on the Toyota system, there is no way to program these into the TPMS ecu.
For any and all people who want to run aftermarket whatever, have whoever installs your custom wheels to place all the sensors into the spare tire, all will indicate the same pressure doing this. This works, I have personally done this.
And for any and all people with a TPMS, check your tire pressure befor bringing it to the dealer and wasting everyones including your own time because you cannot check your own tire pressure. There is a preset threshold for the sensors, it is roughly 28 psi.
I spoke with a sales rep. at wheelsnext.com who said the can sell OEM sensors with a wheel/tire combo. What he didn't know is how they would be programmed to the vehicle. But I believe the cost was $85(he said it was his cost from toyota)
If anything.. if someone is looking for 4 direct tire pressure senors for sale.. i have 4 of them for sale $200 and there urs.. if anyone is needing some contact me
Originally Posted by SquallLHeart
okay...
and BTW every toyota dealership has at least one techstream.. hell we have 7 of them..unless this dealership is in the corner of a hole..i wouldn't go to them..nor would i trust them
