Big Brake Kit
Old Nov 7, 2024 | 07:26 PM
thekyoshi's Avatar
Talking Big Brake Kit
Hello
Is there any options out there that is brand name like willwood?, I have been researching like crazy or I am missing something for a big brake kit that is not TRD for the scion xb 2015.
Anyone with suggestions?
Thank you
Old Nov 8, 2024 | 05:17 PM
Greg S's Avatar
I think Ksport still offers one if you want to shell out the money for it. Best bang for the buck upgrade for the xB front brakes is swapping over to the 2nd gen tC or RAV4 calipers and rotors. Bolts right up and gets you a 3/4" larger diameter rotor with more surface area on the pads. It's a good upgrade in braking while costing a ton less.
Here's a post about it over on clubxb, https://www.clubxb.com/threads/brake...6#post-1514266
Old Nov 8, 2024 | 06:23 PM
thekyoshi's Avatar
@Greg S can this work for the scion xb 2015
https://fastscions.com/products/wilw...-2011-2016-tc2
Old Nov 8, 2024 | 08:25 PM
MileHightC's Avatar
Super Moderator
SuperMod
Originally Posted by thekyoshi
I'd say likely not as brake lines, etc. might be different and no one would warrantee that kit if you're putting it on a car it's not designed for and that's a whole lot of money to spend on a kit you won't be able to return once you've tried to install it and find it doesn't work...I'd look into the RAV4 option.
Old Nov 8, 2024 | 10:27 PM
Greg S's Avatar
It's very possible since the tC2 brakes are a straight swap but I don't know anyone who has done it so no guarantee. Also keep in mind that unless you are changing the rear brakes to something similar you'll want to adjust the proportioning valve.
toober75
10
Dec 17, 2008 02:18 AM
DAILYXB-TYPE-R
19
Apr 19, 2008 03:32 PM
KnowledgePerformance
Aug 11, 2004 07:18 PM
cducker
Jun 23, 2004 08:26 PM
XBman
Mar 17, 2004 04:09 AM
