Brake pad, shim gluing experiment
The brake pedal travel was getting longer again, so either the brake de-airing didn't work or something else is going on.
I noticed the shims on the back of the front pads had moved again. They had done this in the previous video, but I didn't think much of it...
So this time I want to eliminate the shim slip as a possible cause, so I'm using a spray adhesive to glue them on.
I'm also using a "caliper twist" to de-air the brake lines... More effective?? perhaps.
Anyway the initial few test runs seem better. Pedal is firmer and the brakes more progressive with no sudden braking after initial application.
Here's the video
Here's the video
So after 1 month, the brakes feel much better. Just a light touch needed now and quite progressive.
Now what fixed it???
Was it the way I twisted the caliper off after taking the sliding pin bolts out (compressing the piston & pushing air back into the reservoir)
OR
Was it the spray adhesive on the shims
OR
tangsta35
Feb 11, 2014 09:41 AM
