Control Arm Torque Spec?
Old Jun 11, 2020 | 03:26 PM
Jcris's Avatar
Default Control Arm Torque Spec?
Hey
The title says it all. Just need to confirm spec for both bolts. I’m wrenching on a 2014 xB
2.4 automatic.
And what does Toyota call the Arm?
They have some other name that for me is misleading.
Thanks
______
Old Jun 11, 2020 | 05:44 PM
JakeAut0's Avatar
Are you talking about the front or rear?
Old Jun 11, 2020 | 06:59 PM
Jcris's Avatar
Front
Old Jun 11, 2020 | 09:49 PM
JakeAut0's Avatar
If you're talking about the knuckle that attaches to the strut assembly, the two bolts are 177 ft*lbs according to the TRD spring installation guide. If you're talking about the lower control arm then I will look and see if I can find the torque specs.
http://toyotaparts.sparkstoyota.com/...-52080inst.pdf
Old Jun 12, 2020 | 03:12 AM
Jcris's Avatar
Hey
I’m talking about the lower control arm. There is only one control arm on each side which attaches to the
k member at two locations. There is a bolt fitted horizontally (toward the front) and another fitted vertically (toward rear). I need the spec for both of those bolts. Again, I think Toyota doesn’t refer to this part as a control arm. Anyway I appreciate your help.
Old Jun 12, 2020 | 08:17 PM
JakeAut0's Avatar
Ok, so after a lot of searching I was able to find some service manuals and I believe the torque specs are 172 ft*lbs
(Word.doc converted to a picture so it looks a little weird)
I hope these are correct and are helpful
Old Jun 13, 2020 | 04:50 AM
Jcris's Avatar
Thanks
I really appreciate the effort.
172 (Front) seems like a lot. I’ll check it tomorrow
Old Jun 13, 2020 | 06:18 AM
JakeAut0's Avatar
Here is the website where I found the online service manual. The manual seems to be real but you can check it out for yourself.
(Scion xB 2nd gen [2008-2015])
https://workshop-manuals.com/scion/x...nts/page_5170/
Old Jun 13, 2020 | 01:51 PM
62Fender's Avatar
Originally Posted by Jcris
Thanks
This is from the 2006 xB service manual. The year may be older than your model.
8.CONNECT FRONT SUSPENSION NO. 1 LOWER ARM SUB-ASSEMBLY LH
(a) Connect the lower arm to the steering knuckle with the nut.Torque: 98 N*m (1,000 kgf*cm, 72 ft.*lbf)
(b) Install a new clip.NOTICE:If the holes for the clip are not aligned, tighten the nut further up to 60°.
9.CONNECT FRONT SUSPENSION NO. 1 LOWER ARM SUB-ASSEMBLY RH
HINT:Use the same procedures described for the LH side.
10. INSTALL FRONT WHEEL
Torque: 103 N*m (1,050 kgf*cm, 76 ft.*lbf)
11. FULLY TIGHTEN FRONT SUSPENSION NO. 1 LOWER ARM SUB-ASSEMBLY LH
(a) Fully tighten the lower arm with the 2 bolts.Torque:
88 N*m (900 kgf*cm, 65 ft.*lbf) for bolt A
132 N*m (1,350 kgf*cm, 97 ft.*lbf) for bolt B
NOTICE: Do not turn the nut.
Old Jun 13, 2020 | 06:58 PM
JakeAut0's Avatar
Quote:
Originally Posted by Jcris View Post
Thanks
I also thought that the torque specs seem a little high, but I do know that the lower control arms on the 2nd generation xB's (2008-2015) seem beefier than the 1st generation (2004-2007), but I don't know if that has anything to do with the higher torque specs.
(2004-2007 Scion xB lower control arm)
(2008-2015 Scion xB lower control arm)
Old Jun 13, 2020 | 07:45 PM
Jcris's Avatar
Hey Jake,
I checked those bolts this morning and found both at around 100 ft lbs.
I torqued the front bolt to 160 and the rear I left at 100. I’ll see how it goes.
Again thanks for the help
Old Jun 13, 2020 | 09:44 PM
62Fender's Avatar
I don't know why I thought my 2006 xB manual was second generation. Thanks for pointing out the significant differences.
Note to Jcris, please let me know if you want me to delete the gen 1 info.
Wilsito501
Scion xD ICE & Interior
Feb 9, 2020 11:48 PM
PDognite
Jul 10, 2014 04:45 AM
darthmayxj
Oct 21, 2006 03:21 PM
ROBERTM
Scion tC 1G ICE & Interior
Aug 5, 2006 03:24 AM
sciontc_mich
May 14, 2006 05:10 AM
