D2 Coilovers and Hotchkis Sway Bar
Old Mar 22, 2011 | 10:02 PM
xseveredveganx's Avatar
Utah Scions
And it's doubtful that they have anything stiffer for the rear, right? KSport told me what I have is the only rear spring that they offer.
Old Mar 22, 2011 | 10:11 PM
austin.c's Avatar
Same with D2. Swift Springs is my next option.
Old Mar 22, 2011 | 10:29 PM
Utah Scions
That's exactly what I was thinking. I looked at what they offer via their online guides, but I didn't see anything that would be suitable.
Keep me posted.
Old Apr 26, 2011 | 03:27 AM
papo's Avatar
i see it's been a month, how are the coilovers holding on? are they super bouncy/ stiff or do tey ride smooth? any update im thinking about picking these coilovers up since they are cheaper priced than ksport lmk.
Old Apr 26, 2011 | 06:08 AM
CIONIDE's Avatar
Don't do it, non-adjustable crap... next question?
Old Apr 26, 2011 | 09:23 AM
austin.c's Avatar
They never felt bouncy, the dampeners smooth out the ride well. If you turn them to the firm setting, its almost like setting the spring rate higher too. Its a stiff ride, but comfortable on the soft setting, but on firm, it keeps me from rubbing.
Overall 9/10 rating.
Old May 1, 2011 | 06:44 AM
Kingshawty12's Avatar
Any recent pictures?
Old May 1, 2011 | 06:24 PM
austin.c's Avatar
the pic on pg1 are what i drive daily at.
Old Jun 15, 2011 | 02:24 AM
austin.c's Avatar
Anyone else on D2's or similar? i have a question about the rear shocks.
Old Jun 15, 2011 | 03:34 AM
Utah Scions
I'm on KSports. Aesthetically they appear very similar.
Old Jun 15, 2011 | 03:38 AM
austin.c's Avatar
the rear shock, can i use that to hold the suspension down, instead of there equation of allowing 1/3 of the shaft length in the body? it seems like it would be the same as the struts, ya? or no?
Old Jun 15, 2011 | 03:48 AM
Utah Scions
So what you're saying is: can you adjust the shock all the way down into the body, to compress the springs?
I wouldn't recommend it. What are you trying to do? Make the rear stiffer?
Old Jun 15, 2011 | 09:28 AM
austin.c's Avatar
the shock would be at max extension at ride height.
im trying to add preload to the rear spring since i cant find any stiffer ones. D2 wont even offer anything.
Old Jun 15, 2011 | 03:41 PM
Utah Scions
You could do that, but I doubt the shock insert would last that long. Shocks will wear out prematurely if they're constantly at full droop or fully compressed.
What I would do is add bumpstops to the shock. There's polyurethane ones readily available. They come in hard and soft durometers. Can find them at an offroad shop or online.
I'm actually planning on doing this.
Old Jun 15, 2011 | 04:13 PM
austin.c's Avatar
I might as well just have custom springs made to the rate i want at that point. then i can use the shocks at the correct length
Old Jun 15, 2011 | 06:10 PM
Utah Scions
This is true. I haven't looked into getting springs made, but there are options. You could use rear springs from a G35. They may not be the correct length, though. They are about 6k from what I read. Could even use Swift coilover springs. Just have to measure the spring and perches. I was talking to Injected Performance, a vendor for BC Racing coilovers on the forum, about Swift springs. May see if they offer a higher spring rate for the BC coils.
laforze
12
Feb 16, 2016 12:50 AM
maximthegreat
Jan 19, 2016 02:31 PM
carid
Scion tC 2G Aero & Exterior
Sep 1, 2015 09:08 PM
Bmfxtreme
Aug 18, 2015 01:25 AM
Subaru86
Jul 31, 2015 04:00 AM
