Finally on air and 19s!
Old 10-28-2012, 04:06 PM
Scream's Avatar
Default Finally on air and 19s!
Air Lift and 19x8.5 +45 Rotiform NUEs
Scream is offline
Old 10-28-2012, 05:18 PM
flyingemu05's Avatar
sooo sick. how are you liking the air so far?
flyingemu05 is offline
Old 10-28-2012, 05:29 PM
Scream's Avatar
Loving it so far!
Scream is offline
Old 10-29-2012, 04:58 AM
domoboiz's Avatar
Looking good.
domoboiz is offline
Old 10-29-2012, 10:28 AM
Scream's Avatar
It definitely looks like it has positive camber. I had it aligned after we bagged it.
It's an Air Lift kit
Scream is offline
Old 10-29-2012, 03:12 PM
chalibeto's Avatar
Nice
chalibeto is offline
Old 10-29-2012, 04:21 PM
lefty29er's Avatar
BADASS.....Love it
lefty29er is offline
Old 10-29-2012, 04:33 PM
ntm
ntm's Avatar
nice...
ntm is offline
Old 10-30-2012, 01:14 AM
pyroman131's Avatar
REDACTED
pyroman131 is offline
Old 10-30-2012, 04:16 AM
Roller_Toaster's Avatar
<3
Roller_Toaster is offline
Old 10-30-2012, 05:23 AM
jetas's Avatar
So clean!! I just ordered my air management. Just need the struts now
jetas is offline
Old 10-30-2012, 11:50 AM
EGG80x's Avatar
Originally Posted by Roller_Toaster
<3
x2
the NUE really suit the xb
EGG80x is offline
Old 10-31-2012, 02:17 AM
Shadezz's Avatar
Yeah Buddy!! Looks Great!@!
Shadezz is offline
Old 10-31-2012, 03:52 PM
Scream's Avatar
Originally Posted by pyroman131
I've never run an air kit before and I have a few questions for you:
1. How much did that whole air setup run you? I've seen the air kit online for ~$800, but I'm not sure what all you need.
2. What's the ride quality like? Is it a good compromise between stock and a coilover setup?
3. Do you need an alignment each time you change the ride height? Or just one alignment after installing it.
And sorry if they sound like such newbie questions, but I don't know anything about air setups.
(And I didn't bother searching online as I'm interested in your testimonial first.)
Just saw this, been busy lately.
Price was reasonable. Certainly more than $800, but I went with the Air Lift V2 digital air management.
Ride quality is good. Can't compare to coilovers, but it's better than the s-techs I had. The Air Lift struts are 9-way adjustable, so you can pretty much set the ride as firm or soft as you like.
I set it to the ride height I wanted, then had it aligned at that psi. Riding higher or lower will change the alignment, but them's the breaks.
And thanks everyone for the compliments.
Scream is offline
Old 10-31-2012, 05:16 PM
GOLFHAK's Avatar
Default Alignment
I will be doing air in near future, so you get alignment at ride height but when you raise and lower do you lose alignment or back at ride its good?
GOLFHAK is offline
Old 10-31-2012, 05:48 PM
at ride height it comes back close to within spec of your alignment, depending on how accurately your car comes back to its alignment height. or you could just roll without ever getting an alignment like me
Old 10-31-2012, 05:54 PM
Scream's Avatar
So does anyone know if camber bolts will help with the positive camber issue up front?
Scream is offline
Old 10-31-2012, 06:30 PM
GOLFHAK's Avatar
How's your tire wear, I don't want to buy tires every six months just to look good
GOLFHAK is offline
Old 10-31-2012, 06:42 PM
Scream's Avatar
I wouldn't recommend passing on the alignment.
Scream is offline
Old 10-31-2012, 07:35 PM
not too bad but they're definitely wearing down faster than normal. don't take my advice on not getting alignment lol, get it aligned at your ride height and you should be pretty good even though you air up/down.
edit: Scream, are you foglights OEM with lamin-x vinyl on it? also are you running HID's?
Quick Reply: Finally on air and 19s!
