How to Remove Front Rotor on 09xB2?
Old Jun 25, 2013 | 01:41 PM
csmonte's Avatar
Default How to Remove Front Rotor on 09xB2?
I did a search and well didn't come up with much on the xB2.
It seems that the large hub bolt is holding on the front brake rotor. I was going to have the rotors turned with my new pads I'm installing.
Am I missing something. It really looks like that large hub bolt has to come off. It looks like a 12pt bolt somewhere around 1 1/4" or so.
Thanks for quick answers. I was needing this done today.
__________________
Old Jun 25, 2013 | 03:05 PM
06scioxb's Avatar
Team XcelsiA
Team Sushi
17mm bolts behind removes caliper and piston assembly all together and the rotor will just slip out unless it is rusted but a rubber mallet will do the job
Old Jun 25, 2013 | 03:32 PM
csmonte's Avatar
are you sure the rotor/disk is not held down by the hub bolt in the center. it looks seamless. I gave some taps with a deadblow hammer but no movement.
Old Jun 25, 2013 | 05:26 PM
06scioxb's Avatar
Team XcelsiA
Team Sushi
it is not held by the hub trust me on that i have changed many Scion XB rotors it wont budge if the pads are still on it. you need to remove the caliper and piston assembly and then hit it with a rubber mallet all around and it will come off. like i said if the hub looks rusted then it will be super tight but the mallet will take care of that
Old Jun 25, 2013 | 05:36 PM
jetas's Avatar
If the mallet dont work there should be 2 threaded holes. Find a bolt that fits, screw it in til u hear a pop. Dnt be afraid its just the rotor breaking free.
Had to do this on my GFs tC, the rotors wouldnt budge
Old Jun 25, 2013 | 05:51 PM
06scioxb's Avatar
Team XcelsiA
Team Sushi
or just put some heat to the hub where the rotor meets up with in and it will loosen when you hit it with the mallet
Old Jun 25, 2013 | 09:38 PM
xseveredveganx's Avatar
Utah Scions
This. I am 1000000000000000000000000000% positive that the bolt in the center does NOT hold the rotor in place.
You could even use a little PB Blaster on the hub snout and rotor.
Old Jun 26, 2013 | 02:12 AM
csmonte's Avatar
well I got the rotors off, the bolt seem to make light of the situation. I guess my dead blow hammer was a bit to gentle. I've worked on many cars and I just can't believe how the rust had looked like a smooth weld.
well thanks for your help and confidence, it made me question myself to get the job done.
tomorrow~have them turned and re-install.
Old Jun 26, 2013 | 02:14 AM
csmonte's Avatar
also, this is exactly what happened. it made a snapping sound, and started to work its way off. thanks for the details.
Old Jun 26, 2013 | 02:53 AM
pyroman131's Avatar
REDACTED
Old Jun 26, 2013 | 03:20 AM
jetas's Avatar
Glad it helped. Im sure those bolt holes are intended for a puller but whatever works right?
djpax
Jul 23, 2010 03:36 PM
TJKASS
21
Jan 7, 2010 08:43 PM
sejanis
Apr 20, 2008 07:07 PM
3min3m2
13
Mar 22, 2008 03:11 PM
mikeguy3086
9
Nov 27, 2006 09:38 PM
