I NEED HELP NOW
Old Mar 4, 2012 | 02:08 AM
da1nonlytc08's Avatar
DelMarVa
Default I NEED HELP NOW
i install tein s-tech springs the other day and now everytime i hit a bump on the road or bridge i hear a tink on the front. what did i do wrong? i cut the bumper to spec. and put it in and it drop to the bottom then dust cover. or did i have to put the dust cover then bumper or doesnt matter? please help
Old Mar 4, 2012 | 02:09 AM
DelMarVa
n its a 2012 xb with a 2.0 -2.9 drop
Old Mar 4, 2012 | 03:28 AM
creamyxb2's Avatar
couple things make sure your bolts are tight. make sure the springs are in the seat. were the old springs were. did you lube the bearings and grease the upper and lower seats.is one up side down.
Old Mar 4, 2012 | 03:42 AM
itscurtsk's Avatar
could be your top hat. you can try to give it a couple days so the springs can settle properly if you know for sure that you didn't put it on the opposite way.
Old Mar 4, 2012 | 05:10 AM
sdsnybny's Avatar
On the Gen one there is a key way on the stock top hat (flat sides) that fits on the top of the strut shaft, if its not seated right it might give you that noise. It will also destroy the top hat in a short while. I think the gen two is the same.
Here is the assembly order for Gen two, does not show the inside of top hat though
Old Mar 4, 2012 | 10:47 AM
DelMarVa
This is wat I kno I put everything in right n wen putting that last nut where the dust cover is we tighten it to the stock nut. N I saw buddy do the left one n it was tighten more. I hear the noise on the right more then the left. N wen I took it off the bearings were already grease
Old Mar 4, 2012 | 06:43 PM
xseveredveganx's Avatar
Utah Scions
Lolwut?
Old Mar 4, 2012 | 08:33 PM
tha_insane's Avatar
I hate s**t like this. Suspensions are like math problems best way to find your mistake is re assemble everything from scratch and look closer at the diagram at the top of the page. Oh and make sure everything is completely tight..
Old Mar 4, 2012 | 11:19 PM
Utah Scions
Dude are you serious? Come on. Math and suspensions? No way!
/sarcasm. You're 110% right. I've performed a couple spring installs and I heard a funky clunking. Took the front wheels off and made sure everything was tight and put together correctly. Sure enough, the swaybar endlink bolt was loose. Both times.
Old Mar 4, 2012 | 11:23 PM
CIONIDE's Avatar
If at first you don't succeed, try try again.
Old Mar 4, 2012 | 11:38 PM
DelMarVa
Hahaha. I think it's the part number48680 that's lose. How tight does it need to be?
Old Mar 4, 2012 | 11:43 PM
CIONIDE's Avatar
Originally Posted by da1nonlytc08
Hahaha. I think it's the part number 48680 that's loose. How tight does it need to be?
On the 2nd-gen it's P/N 90080-17217, and you did replace those two lock nuts instead of reusing them didn't you?
To answer your question:
Torque: 47 N·m (479 kgf·cm, 35 ft.·lbf)
Old Mar 4, 2012 | 11:45 PM
DelMarVa
I reused them
Old Mar 4, 2012 | 11:50 PM
CIONIDE's Avatar
I reused them
That's a no no, you have PM.
Old Mar 4, 2012 | 11:54 PM
tha_insane's Avatar
If you get a weird answer don't try to see what you did wrong redo it from scratch.
Old Mar 4, 2012 | 11:56 PM
DelMarVa
I think I need to go to a pro
Old Mar 5, 2012 | 02:24 AM
sjthompson01's Avatar
Still doing fine on my reused locknut I don't think I will ever have an issue unless I keep taking it on and off! Lol good luck man hopefully you get it worked out.
Old Apr 7, 2012 | 06:38 AM
xtimxmayyx's Avatar
scrape?
