Ksport coilover DIY install help
Does anyone know of any guides for xb2 coilover install?
Just got my Ksport Pro coilovers today for good price. I will be planning to install it myself this weekend, if it's not to difficult.
I just need to know what tools will be required... and what errors I should avoid
If no diy guide available maybe I can make one during my install.[/img]
no install guides i know of
one thing i accidentally did was install the front struts on opposite sides with camber plate facing front to back instead side to side
for first time doing anything like this was not that hard just take a while
goodluck
goodluck
I didn't have a wrench that size to get the bolt off the rear shocks. So I'll just ride with the stock shocks until i have time to remove them. It will probably take like 15mins to swap out.
The install was really easy I could of finished alot faster if ksport included better "instructions". The paper work they included was unreadable. Took me some time to figure out how to tighten the part that connects to the sway bar endlinks.
They should of made that part one piece with the bottom part. Instead of having me guess which angle to put it.
I also wasted time taking the plastic window wiper area off expecting direct access to front strut upper nuts. Total FAIL there because under that its just the cars metal. So i had to put everything back together to go buy a wrench that was long enough.
So after 4hrs and 5 beers I was proud of myself for not breaking my new car. This was my first time installing any suspension part.
I took some random picture and guess i can make it a DIY guide later.
i know what you mean by the weak install instructions.. i did a install on a tC and i dont even think they included instructions...
well mr. stylis posted some pics on scikotics that makes me slightly jealous
Originally Posted by MaxBoost925
Install is simple. Just do not install the front damper adjusters. They don't fit under the tray thing.
hehe. my ksport setup looks a little different from everyone elses
PMed.. ill let mr grant post up when he feels like.. i know youre on vipstylecars so i think he would approve
plus i cant even post the link cause its our chapter section and thats private unless youre registered with scikotics..
I'm registered on the Scikotics. There's a chapter out here and the guy kept trying to badger everyone in the UtahScions to join. I'm not joining because I'm in a minitruck club. I'd rather be apart of a large minitruck club known to be THE lowest rather than just another Scion club.
That's just me, though. :D
Ho ho ho, but does it dump LOW!
I only took couple pictures during the install! So I know how to put everything correctly if i messed up. I will take more pictures when I swap out the rear shocks... and make a guide.
rear
The strut part that connects to sway bar endlink was installed wrong first time. It was like 2 inches to low.
Dampening adjuster hits this metal part. I made a little space with crowbar
rear
