My 08 on Air Ride
My 08 on Air Ride
Big thanks to Jeremy and everyone at Air Lift (www.AirLiftCompany.com) for using my car as their prototype for their air ride kit for the 2nd gen xB's. They made my car their 1st one ever on air ride! The ride is incredibly smooth. I have drove in several cars with air ride, and this is by far the absolute best riding one yet. The install is amazing, too. Not a single component can be seen inside the car! The car can drive dropped all the way down (no turning, obviously). The front sits only 4 inches off the ground! They should have the kit ready for purchase in a few months, check it out for sure! The wheels are 19" Konig After Burners with Toyo Proxes 4 tires.
Here is the install, completely hidden!
ride height:
Lifted all the way, look at that lift!!
ride height:
Originally Posted by lil_will
That is sick! Can you get some pics of the air ride components under the mat?
ummmmmm you can go lower but there components on kports all the way down with stock tires i can make the front end sit on the ground and in the rear must cup the rear beam so you cant go lower
Originally Posted by detroitbassxb
The rear technically can go lower, but I wanted it to lay out even when dropped all the way.
I've always heard it reffered to "dego". But I'm not sure if it's politically correct or if I'm even spelling it right...
But it does look good for sure!!! Almost as low as Marshall!!
Originally Posted by redline8k
That looks great! whats the rim width, offset and tire size? Id love to tuck some 20's...Also is the reason its not layed out because of the wheels. If you go smaller will it go lower? 18's?
-nick
-nick
