Uas bag problems
Old Aug 4, 2014 | 07:29 AM
Exit_8_xB's Avatar
Default Uas bag problems
So I got under my car today to do an inspection of my air setup and noticed both my rear air house two bags are cut. Both are getting sliced by the lower spring perch closest to the shock mount. Anyone else on uas have this problem? Good thing these bags are pretty cheap.
Old Aug 4, 2014 | 06:52 PM
Exit_8_xB's Avatar
I may have to do the same.
Old Aug 4, 2014 | 09:21 PM
xseveredveganx's Avatar
Utah Scions
I've never ever had this problem.
Because static.
Old Aug 5, 2014 | 04:01 AM
Exit_8_xB's Avatar
Good point vegan but not really relevant is it?
Old Aug 5, 2014 | 09:37 PM
Utah Scions
Yes. Very relevant. If the bag is touching the perch the spring pocket, cut it down.
Problem solved.
You're welcome.
Old Aug 6, 2014 | 08:47 AM
Exit_8_xB's Avatar
I don't think cutting it is the best first move. If cutting it was the answer then everyone running uas and randode would do it. I've never heard of anyone having to do that. Hopefully more people that are actually on air chime in with their experiences.
Old Aug 6, 2014 | 11:15 PM
Exit_8_xB's Avatar
I like that idea. Might have to try repositioning the bag and protecting the edge.
Old Aug 7, 2014 | 03:28 AM
Utah Scions
You could also see how the bag is acting at full drop by jacking up the rear, placing boards under the rear tires, and airing the car out. This way you can still get under the car and see how everything is sitting. The lower cup may be plain too short.
Old Aug 25, 2014 | 03:55 AM
posiden's Avatar
I have the same issue and I fixed it, it worked for me!! I got 3/8 air line and cut it down the center on its side with the curve with a dremel. and used epoxy adhesive filled the air line with it and pushed it along the edge of spring perch and now when my bags rest on the perch the rest on the air line. I check them every so often and no issues I would post a picture but don't know how
Old Aug 25, 2014 | 04:01 AM
posiden's Avatar
Default figured it out
here is that picture
Attached Thumbnails Uas bag problems-1910007_621221761327349_9136703774491124471_n.jpg
Old Aug 27, 2014 | 03:48 AM
Exit_8_xB's Avatar
That's what I need to do before the cuts get worse.
cfarrrias
Mar 27, 2015 06:28 PM
kahsperr
Regional - Pacific South
Mar 26, 2015 06:25 PM
posiden
Mar 22, 2015 03:03 AM
yamahamx117
Scion xD Suspension & Handling
Dec 25, 2014 01:54 PM
LinexA
Nov 21, 2003 02:54 PM
