dub rims
Old Jul 28, 2007 | 12:25 PM
vanstoaster's Avatar
Default dub rims
I want to put dub 18x8.5 +45 dirty dog 5 W/225/40/18, but I'm not sure if they will stickout to far or rub. Any help would be graet
Old Jul 28, 2007 | 10:41 PM
Liquid-R1's Avatar
http://www.1010tires.com/WheelOffsetCalculator.asp
It will probably stick out just a tiny bit. I can't tell you if you will have clearance on the inside though..
Old Jul 29, 2007 | 01:26 AM
mikemann's Avatar
you should be okay. As a reference point. Alot of guys are doing 18x8's with 40 offsets or 7.5"s with 35 offsets. Those all sit pretty flush with the wheel well. I have 7.5" +38 for example and it's pretty close to flush. Using that above calculator you would be sticking out 1mm less.
Old Jul 29, 2007 | 03:54 AM
So what I get from this is the wider the rim the larger offset is needed to get tire flush to out side of wheel well. With a 225/40/18 tire and stock springs I should not have problems with inside clearance? Or front tire rub on inside of tire well while turning? This is all new to me and I don't want to depend soley on the suplier of my new wheels,
Old Jul 29, 2007 | 05:24 AM
mikemann's Avatar
I'm running the same tire size, no rubbing issues. plenty of room in that regard. I'm also lowered with TRD springs. Non-lowered, you'll have more than enough room.
Old Jul 29, 2007 | 12:41 PM
thank you for your advice and our toaster thanks you Pics will be posted when shoes are mounted,about two weeks
Old Jul 30, 2007 | 05:34 AM
CodyGottaBox's Avatar
how ya gonna post a forum quoted DUBS and talk about puttin 18s on your car... man go with 20s... fo real... its the only wheel that actually fits your wheel well... heres some pics of mine.....
also put trd lowering springs so if your runnin stock suspension your easily fine.... with my trd no rubbin at all i can bottom the suspension out and it wont rub lol..... and you can turn the wheels all the way with out rubbin... man i feel like im the only one with 20s.... lol some man up and do it too..... car still rides great... i got 235 30 tires with a +45 offset dude .......... do it
Old Jul 30, 2007 | 02:21 PM
Found a local shop that will charge $1400 w/goodyear tires which is what made the 18x8.5 my choice. If I could find 20's I like for that price I would.
Old Jul 30, 2007 | 10:02 PM
ExcelRevs's Avatar
i'm saving my cash flow for 20s...i'm wit u codygottabox
Old Jul 31, 2007 | 04:38 AM
thanks man trust me the 20s really dont even look like em... more like 18s.... because the wheel well is so big... when you get up close you can def tell there huge ;) they look and drive shawwweeeeeet
Old Jul 31, 2007 | 12:33 PM
xbbox's Avatar
Revolt Imports
DeepSouth Scions
I want to go with 20's, but only if I can fit a 35 series tire on there with a 1" drop, anybody have that?
Old Aug 4, 2007 | 11:32 PM
kyleng's Avatar
hahaha...very nice with the 20s man. i m still not sure what size. i lowered my xb with eibach spring. should i go 18, 19, or 20 ?
Old Aug 5, 2007 | 05:46 AM
avus's Avatar
sIcKsCiOnS
225/35R20s are the tire size you'll need to fit with no rubbing
eujin
Feb 23, 2016 01:18 AM
axB
Sep 18, 2015 06:11 AM
peruviann
Sep 14, 2015 06:35 AM
Robineileen324
Sep 14, 2015 06:21 AM
JZA70
Sep 12, 2015 09:37 PM
