Enkei J10's on an xB Blackberry
Any thoughts on how these will look?
http://www.discounttiredirect.com/di...004&wd=17&rw=7
I'm 99% sure they're the right size for the xB2. If someone can confirm that to 100% I'd appreciate it. Also, what tire specs should I be looking at for proper fit?
Thanks for the input!
You could go with 215/50-17 on a 7" wide wheel, if you want a little larger diameter to fill out the tire/fender gap a little more.
The vast majority of owners go with 225/45-17 which maintains approximately the same diameter as the stock 16" tire, and puts a little more meat on the ground.
With the more aggressive +38 offset, I would suggest the 225/45-17.
