How to Install Hub Centric Rings?
Old Sep 8, 2008 | 10:38 PM
BBN-Boys's Avatar
Default How to Install Hub Centric Rings?
As I understand....
My Ace Alloy wheels has a hub bore diameter of 73mm and our XB has a 60.1mm hub diameter.
Outside Diameter (Wheel Bore Size): 73.00mm ( See Dimension B)
Inside Diameter (Vehicle Hub Size): 60.10mm ( See Dimension A)
How is the actual ring installed?
Is it installed on the wheel or the vehicle hub?
Do you use any adhesive to keep the ring on?
Thanks
Old Sep 8, 2008 | 11:46 PM
coryjames's Avatar
here is your sign ddddddddeeeeeeeeeerrrrrrrrrrrr
lol it fits in your wheel and on your hub think of it like a bushing nothing holds it but the wheel when you get it you will understand
Old Sep 10, 2008 | 07:43 AM
tctuning's Avatar
I have them on my front wheels and they are plastic , kind of like a washer that fits the center whole of your wheel they only go on the front wheels ....my set up is tight and no vibrate or bouncing or steering wheel shakes at all...
Old Sep 10, 2008 | 08:37 AM
BBN-Boys's Avatar
Hey thanks for the replies....
I think it usually comes in a 4 pack. Why wouldn't the rear wheels require these rings also?
The ones I purchased are made from polycarbonate material. I read somewhere that these are preferred over the plastic or aluminum/metal ones.
Old Sep 10, 2008 | 03:58 PM
Leo_EdgeRacing's Avatar
You need four rings. I usually install them into the wheel and then mount the wheel onto the car.
Old Sep 23, 2008 | 03:25 PM
RGuess's Avatar
Default Hub-Centric Sizes...
I'm a firm believer in Hub Rings. My SRT Magnum 22s shook all over the place, I even had someone "straighten" them, before I learned about the rings, now smooth as can be !! The ones I chose are black polycarbonate, I was warned about the aluminum ones, because they corrode, and could damage the hub bore in your aluminum wheel. The main reason you use them, is to insure the wheel is concentric to the hub assy. Years back, the lug nuts were used to "center the wheel", but if the lug holes in the wheel are too much larger than the studs, it can allow the wheel to mis locate slightly. Chances are you won't notice it, until higher speeds, But the taller the wheel, the more effect it will have on the "roundness/balance" Because the moving mass is farther from the center of rotation, the wheel may bounce a little. Ever notice tire shops balance using the center bore, not the lug pattern ???
On a related note, I'm lookin for some OEM type wheels ( Lexus / Toyota / ETC.. ) and no one ever lists the Hub Bore Diameters... Anyone know where to get that info ? I can match up the lug pattern and the offset, but I'd hate to buy and pay for shipping just to find the hub bore too small... I could make a set of "custom" rings as long as there's clearance... Is the Camry the same 60.1mm ? What about the Lexus GS400s ??
Thanks, Rich...
Old Sep 24, 2008 | 12:38 AM
BBN-Boys's Avatar
Thanks for your input. On my past wheels, I never noticed that my wheels had the rings.
From what I understand, most Toyotas are 60.1mm hub bore. Not sure about Lexus.
Old Sep 24, 2008 | 12:48 AM
STNC's Avatar
And where do you get these rings?
Old Sep 24, 2008 | 12:54 AM
BBN-Boys's Avatar
Do a search.... plenty info.
I purchased some off of ebay a few weeks ago. Get the polycarbonate stuff.
Old Sep 24, 2008 | 12:57 AM
STNC's Avatar
http://cgi.ebay.com/ebaymotors/Scion...mZ170184783566
Should these work with 18" wheels on a tC?
Old Sep 24, 2008 | 01:01 AM
BBN-Boys's Avatar
Not sure. You'll need to contact your wheel manufacturer for the outer bore specs.... I was fortunate that both of my wheel sets are 73mm.
Old Sep 24, 2008 | 01:16 AM
BBN-Boys's Avatar
http://www.justforwheels.com/index.j...=how&track=GHR
Old Sep 24, 2008 | 01:05 PM
RGuess's Avatar
No way to know for sure, as wheel manufactures make different sizes. You could call a tire store that sells your wheels, or the manuf. Hell, just go out and throw some calipers on them!! 60.05mm = 2.364 inches / 73mm = 2.874 inches...
Rich...
Old Sep 24, 2008 | 03:30 PM
We carry plastic ones for $25 shipped and aluminuim ones for $30 shipped. Let me know if you need a set.
Old Sep 24, 2008 | 04:01 PM
STNC's Avatar
I am interested, I just need to get the info on my wheels
Old Sep 26, 2008 | 06:15 AM
STNC's Avatar
Ok, so my wheel manufacturer came back and told me that it the outer bore is 73.1mm
So will these work?
Old Sep 26, 2008 | 02:47 PM
They will not fit. Those rings are 72.6 to 54.1. You need 73.1 to 54.1.
Old Sep 26, 2008 | 02:50 PM
STNC's Avatar
pm'd
SuBSiN
Mar 13, 2015 04:02 AM
Frustratez
Feb 26, 2015 04:03 PM
tc_Jake
Dec 31, 2014 01:45 AM
Alvie
Dec 12, 2014 05:04 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
