question newbie
hi , i am new on this forum , i live in french canada (sorry for my bad english) i just buy a white xb ( i love it).
my question is : i can put on this a wheels 20 -8.5 offset 40 with tire 225-40-20 with no rubbing
i dont want lower my car because the snow is hight here in winter.
thank s for youre respond.
What made you think about 225/40-20 tires? I don't know of any companies that make that size tire. It doesn't really matter anyway, because at over 27" in diameter, I think it would be too large for the xB.
If you're not going to lower it, go with 235/35-20 tires.
Originally Posted by 2008XBlimited
go with 215/30/20
The wheel openings will allow for a larger diameter tire, and the 20's need it, or they will feel like you're riding on solid steel. The 235/35's will fit, and I wouldn't recommend anything smaller than 225/35 for your needs.
i have found a good deal on tire 225/40-19 with 4 19-8 wheels offset 38
always not a lower kit .rub or not
sorry for another question but i really need this meat on my tire , here the road are very bad and i not like 18 for wheels (it s too small on xb).
thank s cionide for your help.
235/35 have wider tread and more sidewall height than 225/35.
225/35-19 = 8.86" wide, 3.10" sidewall height, and 25.20" diameter.
235/35-19 = 9.25" wide, 3.24" sidewall height, and 25.48" diameter.
Stock 205/55-16 = 8.07" wide, 4.44" sidewall height, and 24.88" diameter.
For 19x8 +38 offset, with no lowering springs, go with the 235/35-19 tires.
225/40-19 will work fine on those wheels, but it is a fairly uncommon size that is hard to find (usually special order), and generally very expensive. Here is Discount Tire Direct's selection to give you an idea:
http://www.discounttiredirect.com/di...25&ar=40&rd=19
To compare to the above sizes:
225/40-19 = 8.86" wide, 3.54" sidewall height, and 26.09" diameter.
I've never seen anybody run a 225/40 on 19" wheels. I stand by my recommendation of 235/35-19 tires.
bootlgr
Jan 26, 2016 01:22 AM
