Spacer help! 18X7.5 +42
Old Apr 1, 2011 | 04:38 PM
Scream's Avatar
Post Spacer help! 18X7.5 +42
My setup: 18X7.5, +42, 225/40-18
I've found a couple of setups with this offset running 8-9" wide wheels, but none with 7.5.
Let me see if I understand...
My rims are +42, so adding a 5mm spacer would put the offset out to +37; 10mm to +32, 15mm to +27 and 20mm to +22, correct?
I've used the calculator that I found in one of CIONIDE's posts, but I can't figure out how much extra room we have to fill up. I'm leaning towards a 20mm spacer since my wheels are a 1/2" narrower than the 8" rim recommendation that I found. I also plan on using either DF210s or S-Techs, so the rear will be 2.1-2.2" lower, another concern.
Here's what the calculator shows for +15mm spacers:
Suspension: 100% clear (leaves even more room than OEM)
Fenders: Package will stick out 28 mm (1.1'') farther.
Wheelwells: Will fill out the wheelwell by extra 3 mm. Almost no difference
Here's what the calculator shows for +20mm spacers:
Suspension:100% clear (leaves even more room than OEM)
Fenders: Package will stick out 33 mm (1.3'') farther.
Am I on the right track?
Old Apr 2, 2011 | 06:32 PM
CIONIDE's Avatar
With your tire & wheels specs, on DF's or S-Tech's, go with 15mm rear spacers, no front spacers, and be done with it. You'll sit back from dead flush about 1/2" both front and rear (they will match for flushness instead of the rears being out more with 20mm spacers) and you shouldn't have any rubbing issues.
ruzzzell
Scion xB 2nd-Gen Wheel & Tire
Oct 11, 2015 04:18 PM
terrye
Sep 26, 2015 12:24 AM
axB
Sep 18, 2015 06:11 AM
rvascion
Aug 16, 2015 02:26 AM
Krysune
Jul 11, 2015 09:30 PM
