to stager or not?
Old Jun 5, 2008 | 03:18 AM
sp2's Avatar
sp2
Defined3
Default to stager or not?
im sporting some ksport coils rightnow and they are set pretty low
the wheels i was looking into come in
18x7.5 45mm or 48mm
18x8.5 38mm or 53mm
i would like a really nice wide stance but i need help picking wheel width and offset
would the 18x8.5 fit in the front ? i kinda guessed no but just checking
if 18x8.5 didnt fit up front i wanted to do that in the rear. with 18x7.5 in front but i wasnt sure if would be better to just get 18x7.5 all around
what u guys think?
finally what would be the best set up for my xb2 of course with no rub
thanks for all your help
Old Jun 5, 2008 | 04:38 AM
CIONIDE's Avatar
If you want to drop it really low on the Ksports, with no rubbing, and no fender rolling, then go with the following:
18x7.5 +45 on the front, with 225/40-18 tires
18x8.5 +38 on the rear, with 235/40-18 tires
Nice look, nice tuck, no rubbing, no fender rolling, no problems!
The tire & wheel fitment Guru has spoken.
Old Jun 5, 2008 | 07:09 AM
sp2's Avatar
sp2
Defined3
thanks alot man
when it comes to tire rotaiting ud just rotate them left to right ?
would the fronts end up wearing quicker because of these?
dont mind to much just curious
Old Jun 5, 2008 | 07:22 AM
CIONIDE's Avatar
With staggered wheels, you can only rotate side to side if the tires are NOT uni-directional. If you get uni-directional tires that have an arrow showing which way they should rotate, you will not be able to simply swap wheels from side to side to rotate. Most performance tires, and even some all-season tires are uni-directional.
Old Jun 5, 2008 | 07:41 AM
sp2's Avatar
sp2
Defined3
ok thanks for the help cionide
Old Jun 5, 2008 | 07:49 AM
CIONIDE's Avatar
You're welcome, here to help, pics when you're done!
Old Jun 5, 2008 | 08:25 AM
sp2's Avatar
sp2
Defined3
ok i will for sure
prob be about a month
Old Jun 5, 2008 | 04:51 PM
Go_HIN's Avatar
just get a more aggresssive offset for the rear.... I think its completely dumb to stagger our cars when we're FRONT WHEEL DRIVE. makes completely no sense other than looking like a RWD car.
Old Jun 6, 2008 | 12:21 AM
sp2's Avatar
sp2
Defined3
well still if i get a diff offset i still couldn't rotate the tires the same so might as well go wider
thanks for opion though
Old Jun 6, 2008 | 12:29 AM
coryjames's Avatar
well you want to know about ksports i know best dont stager if you want to go low pick a wheel with a big offset and a little different in the rear if you stager you will rub i had mine pretty low on 20s i could barley ride around i got rid of that i am going 17s now lol
Old Jun 6, 2008 | 02:12 AM
cubanix's Avatar
don't listen to the negative people out there .. it's your box and
you can do whatever you want to it.
Old Jun 6, 2008 | 03:19 AM
sp2's Avatar
sp2
Defined3
i know
of course
you are always the final say when it comes to ur ride
Old Jun 6, 2008 | 04:14 AM
Go_HIN's Avatar
Well i hope i wasn't trying to sound negative.... just basic function over form. Why drag more weight and wider tires that are gonna be more expensive... going w/ wider rear's will just slow the car down even more.
the topic was to stager or not.... i think not... just go w/ the same wheels all the way around so you can rotate and do all that good ol' stuff. The only point in going staggered would be for looks and if thats what you want then lower offsets is exactly what I would recommend.
Old Jun 6, 2008 | 04:17 AM
Go_HIN's Avatar
The coilovers don't make a difference with your car not fitting.... it actually helps in that you can customize how low or how high you need to go. Wheel width and offsets are probably the most important provided you get the right size tires. With 20" wheels you limit yourself even more.
Old Jun 6, 2008 | 07:38 AM
sp2's Avatar
sp2
Defined3
dont worry i dont get all ____y from ppls opions
thats why were here to give each other advice ur say if u wana agree or use that advice right?
haha
yea idk i got like a month or more to decide
jus my wheels are gunna be about $2k
i hate having such expensive tastes
haha
Old Jun 7, 2008 | 05:38 AM
MaxBoost925's Avatar
I'm all style. I don't drive a performance car so therefore I stagger.
I have 18x8 front 18x10 rear.
Old Jun 7, 2008 | 06:40 AM
Go_HIN's Avatar
^^well atleast he knows how to really do it up.... 18x10's and AME Shallen's I approve!
Ben180
Scion xB 2nd-Gen Wheel & Tire
Feb 17, 2013 10:32 AM
flyingtoaster
Mar 10, 2012 12:29 AM
scionblueblitz
Regional - Pacific South
May 13, 2007 08:17 PM
pdjray
Scion tC 1G Wheel & Tire
33
Mar 12, 2007 09:46 PM
