TPMS
Ok this may sound dumb but i keep seeing people mention problems with the TPMS. When adding aftermarket wheels, do certain wheels just not accept the TPMS, or is it just certain wheels?
Somebody said that you make a PVC pipe tube, put the sensors inside cap them off with a fill valve on one end and presurize the tube. Then throw the tube in the trunk and furget buot it! No blinking light
^^Please explain how this indicates someone doesn't care about their (not there) car as I'm a retard and slow. I've been driving for 20 years without retard warning lights, oh I mean TPMS so I think I'll be fine as I care enough about my car to use a gauge to see if my tire pressure is low.
From my research the options are limited. If you buy rims and tires that come mounted and balanced you incur a charge to swap the sensors. If you get a new set of sensors with the wheels the dealer has to reprogram the sensors and your old ones will not work. If there were a DIY solution my new rims would be coming with sensors but there isn't.
Originally Posted by 2Hip
My fault. I thought your point was covering the tpms light was for retards who don't care about their car, but I see your point now. Punctuation in the first post would have made it more clear.
punctuation is for priccccks like you
i lend my help
and i care for my car probably more then you do
its ok i lend a hang get bashed for it
So I admit I miss understood you and now I'm a *****.
Yes you probably care more for your car then me as my car is more of an appliance to get me to and from work. I've already had my sport cars that I cared to much for. I'm liking not worrying about this car so much.
Have a nice day and chill a little.
So I just got some new alloy 17" wheels and they swapped the sensors no problem (45 series tire), they tried to reset the tpms but it wont take. when you turn the key on the light flashes for a minute then stays lit. What gives?
