Tpms
Old Apr 17, 2010 | 10:30 PM
mudvayne2k6's Avatar
Unique Scionikz
Default Tpms
When you get aftermarket rims what happen withs the sensors from the factory tires? Can they be installed in the new rims?
Old Apr 17, 2010 | 11:03 PM
lltysonll's Avatar
yeah you can swap them over to the new rim.
if you dont your tire pressure light on the dash will blink then stay on.
just wont have any notice if your tires are low on air. Youll have to keep checking them.
Old Apr 17, 2010 | 11:24 PM
TrevorS's Avatar
The OE tires and TPMS sensors can both be moved to aftermarket rims, as long as the rims accept TPMS sensors (not all rims do). Bottom line is the new rims have to be TPMS compatible.
Old Apr 17, 2010 | 11:27 PM
rsw1124's Avatar
and if your new tires have same air pressure as stock which is 35 pounds the light wont be on if you change to 17 s
Old Apr 18, 2010 | 04:24 AM
Unique Scionikz
So even with the difference in air pressure the sensor will not work right if the rim is to say to be conpatible because low pro tires seem to have differen air preasure so then its no point to put the tpms sensor on if its still gonna stay on imma get 18x8.5 rims
Old Apr 18, 2010 | 10:49 AM
XBinRochester's Avatar
As far as I understand it, that you can use the sensors with different size wheels and pressure, you just have to reset the computer for the new tire pressure. Scion uses the same sensors in the 16", 17" and in the TRD 19" wheels so size doesn't matter.
Old Apr 19, 2010 | 01:01 AM
curtisc's Avatar
There are instructions in the manual on how to set the pressure for TPMS...very simple.
kleecker
Scion xB 2nd-Gen Wheel & Tire
May 22, 2016 06:10 AM
paolodoctolero
Feb 22, 2015 06:35 AM
ptperson
Regional - Pacific Northwest
Feb 13, 2015 04:03 AM
houstonhelix
Apr 29, 2009 10:20 PM
RogerTTR
Nov 18, 2007 10:20 PM
