TPMS sensor and valve question
Old Feb 23, 2010 | 08:49 PM
Joeynenj's Avatar
Default TPMS sensor and valve question
hey, I have a question about TPMS, its valve stems and general tire replacement or repair. Im running stock goodyears and stock rims on my 2010 xb, when it comes time for the tires to be replaced or repaired, do I need to inform the shop to be careful of the sensors or do they still manhandle everything regardless ? Do the metal valves need to be replaced like commonly done with rubber ones? Im asking now so when the time comes I dont get ripped off. Thanx
Old Feb 23, 2010 | 08:55 PM
draxcaliber's Avatar
you should inform them when they're mounting your new tires that the car has TPMS sensors and if they break them, guess what, they're buying you new ones.
and no, you don't need to replace the valves unless they're leaking.
Old Feb 24, 2010 | 12:28 AM
N0AuTHoRiTy's Avatar
To be on the safe side, you should inform them about the TPMS sensors. Nowadays, alot of new cars are required to have TPMS sensors, which most shops should have received training on how to go about removing the tire properly. Just make sure before you leave the shop, that everything is in proper order and no TPMS warning lights are on. If the latter, make sure the shop handle's it before you officially take the car back in your possession.
Old Feb 25, 2010 | 02:14 AM
xbaholic's Avatar
I would definitely inform them. But then again, even though I told the people that did my rims about them, they manhandled them anyways and messed them up hopefully you have better luck than i did!!
Old Feb 25, 2010 | 04:38 PM
bb0793's Avatar
I would mention it to them. If they don't know what you are talking about, I would get out of there.
Old Feb 25, 2010 | 05:41 PM
HATEnFATE's Avatar
They break it, they buy it.
kleecker
Scion xB 2nd-Gen Wheel & Tire
May 22, 2016 06:10 AM
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
ptperson
Regional - Pacific Northwest
Feb 13, 2015 04:03 AM
xBassist
9
Jan 21, 2004 07:34 PM
