Wheel/Tire question
I realize this is a stupid question that has probably been asked a million and a half times. However, I am not sure I understand how to tell if the wheels/tires I want will fit properly on the car and not cause rubbing. I don't fully understand how the offset works, and how I can make sure that they will be flush with the sides of the car (ideally).
The rims I want are Enkei Performance GW8 with the following specs:
Offset: +42mm Backspacing: 5.90" Bolt Pattern: 5-114
Rec. Tire Size:215/45-18
Weight: 22.8lbs.
I am not sure what tires are even good anymore (i haven't focused on these things in years sadly). So any tire recommendations also would be fantastic.
Thanks, and sorry if this is a stupid question.
Weight: 22.8lbs.
I'm guessing you meant TRD springs, not coilovers. Those GW8's look kind of busy IMO, but as long as you like them, that's all that counts. At 7.5" wide with +42 offset, the outer face of the front wheel lips will sit back about 5/8" from dead flush, and the rears will sit back just over 1". They're 18x7.5, so like FroZone said, I'd recommend 225/40-18 tires for these particular wheels.
Sorry for not replying earlier, I was out of town.
Yes, I did mean TRD springs, my mistake. The wheels are definitely a little busy, but I do like them. I have a black Xb, and I am going to do a red/black theme with the interior/lights, so red and black rims make sense to me. I could go with some standard black 5 spoke ones also if I wanted to.
What are the differences between 225/40-18 and 245/45-18? Will I need to buy anything special (like wheel spacers) for these rims/tires to properly fit?
What tire brands would be recommended and why?
The 245/45-18 tires are .8" wider (20mm) and more than 1.5" larger in diameter than the 225/40-18. Far too big to be putting on the xB2 with a TRD drop. I think the tire and wheel calculator we all use will help you understand how the changes from stock may or may not work, and what the resultant changes will be:
http://www.rims-n-tires.com/rt_specs.jsp
Keep in mind that the stock wheels are 16"x6.5" with +45 offset, and the tires are 205/55x16".
If you want the rears to match the front for distance from the edge of the fenders you can throw on some 15mm rear spacers. If you regularly drive with a full load of passengers or cargo, then you might want to go with 10mm spacers. And don't forget a set of hubcentric rings, as well as new lug nuts.
I stay away from recommending specific brands since I have so little personal experience, but I'm sure some others will chime in with their own recommendations. I will say that I have been happy with my Falken Ziex ZE912's for all-season performance tires that are non-directional and reasonably priced.
Ohhh, so its the dimensions of the tire itself. That makes a lot more sense. And if they are going to cause rubbing, then I definitely do not want them. Do the 225-40-18 not last as long, since they are not as thick/large in diameter?
Do I even need spacers? Will the tires look odd if I do not put spacers on? How do the spacers work in relation to causing rubbing? Will they cause rubbing/extra rubbing at all?
Are there such things as wheel locks. Something like a hub cap that I can lock on with a key so no one can steal them? I ask because my wife has already had her stereo stolen, and multiple other people have had their cars stolen from (odd because we live in a nice neighborhood)
Sorry for the all the questions, trying really hard to learn all of these things
Here's a lot of good info to educate you quickly:
http://www.discounttiredirect.com/di...nfoCenter.jsp?
http://www.tirerack.com/about/techcenter.jsp
2. No, people use them to achieve a particular look and get the rear wheels to match the fronts for how flush the wheels are to the edge of the fenders. The rear wheel hubs sit in about 1/2" more than the fronts on the 2nd-Gen xB.
3. Spacers push the wheels (and tires) out closer to the edge of the fenders by the amount of their thickness. Push out too far, and you can have rubbing issues.
4. Not if they are sized properly in comparison to the width & offset of the wheels, as well as the size of the tires, and take into consideration what the xB is lowered on (springs, coilovers, air bags).
When you find some wheels you like, hit me up with PM and I can help you with size, offset, and tire size.
bootlgr
Jan 26, 2016 01:22 AM
