will 19x8 plus 30 offset work or 19x8 plus 40 offset
iam trying to get some wheels 19x8 plus 30 or 19x8 plus 40 offset??? and iam going to run 225 35 19 it that okay??? 08 XB2???
even with a 19x8 application, i believe the +30 offset will stick out too much
which could cause rubbing issues -- unless you plan on rolling fenders and adding camber, then go for it you'd have no such problems with the +40 offset |
okay thanxs!!!!!!!for the info!!!!!!!
I have 18x8s with +38 offset. +30 is only 8mm more so it shouldn't be a big deal unless you lower the car down to the tires.
http://216.77.188.54/coDataImages/p/...DRRims002s.jpg |
here is what i have 19x8 +45 and 19x9+35
flush fit https://img.photobucket.com/albums/v...r/CIMG0113.jpg 35 up front should becuase i can come a litto more out on the frint.. 30s will work if you camber it.. |
