will 19x8 plus 30 offset work or 19x8 plus 40 offset
Old Aug 28, 2007 | 07:34 PM
bad_bhelle's Avatar
Default will 19x8 plus 30 offset work or 19x8 plus 40 offset
iam trying to get some wheels 19x8 plus 30 or 19x8 plus 40 offset??? and iam going to run 225 35 19 it that okay??? 08 XB2???
Old Aug 28, 2007 | 08:20 PM
avus's Avatar
sIcKsCiOnS
even with a 19x8 application, i believe the +30 offset will stick out too much
which could cause rubbing issues -- unless you plan on rolling fenders and adding camber, then go for it
you'd have no such problems with the +40 offset
Old Aug 28, 2007 | 08:38 PM
bad_bhelle's Avatar
okay thanxs!!!!!!!for the info!!!!!!!
Old Aug 30, 2007 | 12:10 AM
chadfo's Avatar
I have 18x8s with +38 offset. +30 is only 8mm more so it shouldn't be a big deal unless you lower the car down to the tires.
Old Aug 30, 2007 | 05:19 AM
eight08customs's Avatar
here is what i have 19x8 +45 and 19x9+35
flush fit
35 up front should becuase i can come a litto more out on the frint.. 30s will work if you camber it..
Sumolance
Scion xB 2nd-Gen Wheel & Tire
15
Jan 30, 2015 05:09 AM
gettoastedinthetoaster
Dec 29, 2014 11:39 PM
2010tc805
Scion tC 1G Wheel & Tire
Dec 12, 2014 06:47 PM
DR_xB
Jul 20, 2004 08:31 PM
scioninla
Oct 30, 2003 08:01 PM
