YO CIONIDE.........
Old Mar 2, 2011 | 09:35 PM
jrincon17's Avatar
Default YO CIONIDE.........
OK 18x8 42mm and 35mm will it fit on df210's , what size tires and will i poke? can i run a 40series? 35mm rear right 42mm front. i dont want poke
Old Mar 3, 2011 | 07:45 AM
CIONIDE's Avatar
18x8 +42 front will sit back from flush (tuck) about 3/8".
18x8 +35 rear will sit back from flush (tuck) about 5/8".
Good to go on DF springs with 225/40-18 tires.
Your set-up has been approved, and you may place your order now.
Old Mar 3, 2011 | 02:18 PM
jrincon17's Avatar
Hahaha ok thanks mang ! Was hoping for a staggered look but i guess thats not quite it. Can you gimme some staggered offsets and sizes for an 18" . Tires and wheels
Old Mar 3, 2011 | 02:30 PM
jnaval's Avatar
Stamp of approval! Looking forward to some pics.
Old Mar 3, 2011 | 03:37 PM
CIONIDE's Avatar
Originally Posted by jrincon17
Was hoping for a staggered look but i guess thats not quite it. Can you gimme some staggered offsets and sizes for an 18".
The differing offsets you posted will get the rear wheels closer to matching the fronts for how flush they are with the fenders, but have nothing to do with staggered. The staggered wheel set-up is generally wider wheels and tires in the rear than the front... something like 18x8 front and 18x9 rear, with the same or similar offsets. Have you found any wheels you like yet? That would be the first step, then we can examine the sizes & offsets to see if they are available in a set-up that will work for what you are trying to accomplish.
Old Mar 3, 2011 | 03:40 PM
jrincon17's Avatar
OK WILL DO BRB !
Old Mar 3, 2011 | 04:29 PM
jrincon17's Avatar
Ok heres my choices
18x8 35mm or 45 mm
18x9 35mm or 45mm
35mm right? What tires should i run?
Old Mar 3, 2011 | 04:36 PM
jrincon17's Avatar
ok found another
18x8 35mm
18x10 35 mm or 48mm
Old Mar 3, 2011 | 08:05 PM
CIONIDE's Avatar
18x8 +35 will be fine up front,with 215/40-18 tires on the DF drop.
18x10 +35 will poke out back, +48 won't poke but I'm not sure about brake caliper/suspension clearance tucking this wide of a wheel under the fender.
Old Mar 3, 2011 | 08:12 PM
jrincon17's Avatar
IM BETTER WITH THIS HUH?
Ok heres my choices
18x8 35mm
18x9 35mm
WHAT TIRE SHOULD I RUN HERE? AM I BETTER WITH THIS?
Old Mar 3, 2011 | 08:33 PM
CIONIDE's Avatar
Much better.
18x8 +35 with 215/40 tires up front.
18x9 +35 with 225/40 tires out back.
Old Mar 3, 2011 | 09:04 PM
jrincon17's Avatar
Ok sounds sexy to me.
Thanks !
