Fog Light Kit and the Firewall
I bought the fog light kit and got it installed up to the "pass the wire through the firewall" step.
How do you work with that pass through housing mounted to the firewall? Kit link http://www.trdsparks.com/displaypart...&parts_id=2297 As seen installed by XDME https://www.scionlife.com/forums/vie...=asc&&start=60 |
if you dont have a proper grabber tool, then youll have to do it the hard way (like i did for my friend) but theres a grommet thats stuck in the fire wall and its up under your dash. youll have to stick the wires down into the engine bay, and then stick the grabber tool through that grommet, then just pull it through. the grommet is located high enough where you cant see it if youre just sitting in the vehicle, so you'll have to sit on the ground and look up into it (under the dash). and its on the drivers side..hope this helped. oh..if you dont have a grabber tool, use a stick and tape the wires to it, then pull it through (its MUCH harder this way but this is how i did it for a friends accord)
the stick method is how i ran the power wires for my scanner, and also the lines for my four corner hide-away strobe kit. |
or just slice the rubber with a knife and push them thru
a straightened wire clothes hanger works real good too. poke it through from the cabin into the engine bay, tape wires to end of wire rod, pull back through. easy as pie.
and the coat hanger idea is good...but we were afraid it'd be too flimsy? guess not thoguh if you had success with it. that would be the next best thing from a grabber tool cause you can just wrap the wire hanger around it... |
I would classify it as simple once you figure out how to do it....I probably spent four hours figuring it out. |
