Scion xD ICE & Interior In-car entertainment and electronics...
Dead mouse in defrost vent
Old 06-19-2010, 05:22 PM
Farmhand's Avatar
Default Dead mouse in defrost vent
During the winter, there was evidence of a mouse in the car (shredded kleenex,...) and we set a trap and caught it. A few months later my wife (who drives the car) complained that the defrost/heater fan was making an odd rumbling vibrating sound. I took things apart and there in the fan was the bloodied and mutilated remains of the unfortunate mouse that found himself in the fan when my wife turned it on. Clean up for the fan and ductwork was done with a Qtip, tooth brush and bleach water.
Things have gotten worse. The mouse guts and gore all over the fan and ductwork from last winter look pretty good now as I reflect back. What I'm faced with today is a dead mouse decomposing quietly in some dark, obscure corner of the ventilation system and reeking to high heaven. The car is hard to be in...horrible if the fan is on.
A couple questions:
1.) Where is the intake duct opening for fresh cabin air. I've got to believe that's where the mice are coming in. I want to put a metal screen over it.
2.) Any ideas on how to get the reeking rodent out without taking the whole dash apart? I have the blower fan out and have used a vacuum cleaner with hose up in the duct work hoping to suck the offender out, but to no avail.
Thanks for any input.
Farmhand is offline
Old 06-19-2010, 07:15 PM
Nateson's Avatar
Simply put, I'm not quite sure, but the dash is actually pretty easy to take out. While you're in there you could even throw some rattle stop material in there. Doing this should give you a good view where everything runs. Here's the link on dash removal.
https://www.scionlife.com/forums/sho...d.php?t=161864
Also a nice trick is to buy a cabin air filter at autozone or wherever and spray it down with a deodorizer (/lime-dead body "jk"). Our car doesn't come with a cabin filter, but has a place for one. Though the trick only works if you have your system set to recirculate. Here's a link for replacing the cabin air filter.
https://www.scionlife.com/forums/sho...d.php?t=178914
Nateson is offline
Old 06-19-2010, 10:22 PM
cobaltbravo's Avatar
I don't know if my dash removal will help, if you wanna get to the enviro intake, you'll need to pull the wiper cowl off. Its pretty easy, I believe there's a write up in here somewhere for the removal. Gl finding the body. If you need a cowl removal how to, let me know.
Sent from my Droid using Tapatalk
cobaltbravo is offline
Old 06-19-2010, 11:27 PM
Farmhand's Avatar
Back again...The fresh air intake is under the hood, under the wiper arm cowling on the passenger side. I found out after a fair amount of investigation and disassembly.
The opening is in the fire wall and is about 10" x 3" in size. It was very easy to install a piece of hardware cloth over the opening once I took the wiper arms off and removed the cowling. I would definately advise ya'll to do the same to prevent turning your car into a mobile mouse maternity ward like mine became.
Here's what I found. Underneath the cowling and next to the wiper blade motor is a great place for a mouse nest. They used the the thermal and sound insulation for their nest. This location provides warmth from the engine during the winter, immediate access to the cabin via the cabin air intake and fairly close the the great sound system included in these cars for all the mice who enjoy the old country tunes, blues and jazz which I'm dialed into.
We feed the birds sunflower seeds in our back yard, keeping the seed in a can in the garage and so the mice also tuned into that great food source. We have changed things. New mice will not get in via the cabin air intake.
I have not found the rotting mouse yet, but I thank all you for your great ideas!! I am still on the hunt!
Farmhand is offline
Old 05-08-2011, 04:04 PM
tribe's Avatar
Farmhand - Great advice! I found two dead mice in my blower motor fan. I only found them after finding a huge vibration in the dash anytime the blower fan was on HIGH.
tribe is offline
Old 05-09-2011, 12:55 PM
Hix
Hix's Avatar
That's nuts! I have mice all over the place out here, I'm so glad all I ever get are tarantulas and ants in my car
Hix is offline
Old 10-12-2011, 03:46 AM
ivanhoe's Avatar
hi,
the wife found evidence of facial tissue bits today. now to put a steel mesh over the fresh air intake is priority. we should keep this post bumped for the unaware owners......
ivanhoe is offline
Old 10-13-2011, 01:22 AM
Lil_Deuce_tCoupe's Avatar
I had a 'mouse hotel' between my engine block and intake manifold - the bastards chewed through the wires on the knock sensor. Check this out:
https://www.scionlife.com/forums/sho...d.php?t=177661
Lil_Deuce_tCoupe is offline
Old 10-14-2011, 06:53 AM
kervin204's Avatar
now am getting ____ed with this mice.
i think am one of the MOUSE CAR VICTIM
cause everytime i open my AC/HEATER it smell so BAD!!! like hell a BAD!!
am 80% sure there is something happening in my defroster!!
Grrrr!!!
kervin204 is offline
Old 10-18-2011, 04:05 AM
ivanhoe's Avatar
well, the priority list got done! s/s mesh(4" by 13") over the air intake accomplished. the oem grill has a screen on it but the mice found a way around it or they're getting in somewhere else? time will tell........
ivanhoe is offline
Old 10-18-2011, 04:25 PM
jct
jct's Avatar
dryer sheets i hear those work too...
i had mouse stuck between my steelie and my hubcap... it couldn't take all the g's so it died in there... and i flung it out into a k-mark parking lot...
jct is offline
Old 10-18-2018, 06:43 PM
slickmickey's Avatar
Default so yeah this happened to me yesterday
i was driving down the highway listening to my audio book and decided to close the windows and just put the ac on low to hear better. it started making a slight tapping sound, almost like a piece of paper stuck in the vent, so i turned it to high to see if it made it better or worse... instead there was a soft thud sound and the WORST SMELL EVER like i almost vomited while going 65mph. must be something dead in there and i just blended it up suddenly. hubby has to try to find it asap, but of course it went from 70s to 35 this morning and i couldnt use the heat cause i cant risk that smell again!!
slickmickey is offline
Old 10-22-2018, 01:01 AM
Farmhand's Avatar
Default Eeeek! It's Mouse Reek.
Sorry to hear about the smelly problem. A decaying mouse in the car will make it a horrible experience to ride in. It is almost a certainty that the mice are getting in through the cabin air intake located directly in front of the glove compartment and underneath the wiper motor enclosure panel. You probably have a large nest under there too. With winter setting in, mice are even more likely to find there way into your car, so I urge you to get a wire screen installed over that opening, and while you're at it, put one over the plastic snorkel that brings air into the engine air filter under the hood. The varmints love to get in there too and nest by your air filter. Of course, cleaning up the fan blower and air ducts is another time consuming matter, but doable. I cleaned the blades of the squirrel cage blower with a Q-tip after removing it. It looked a bit like a mouse version of the "NIghtmare on Elm Street" horror flick with all the blood and mouse gore. All the best!
Farmhand is offline
excessads
09-15-2015 05:28 PM
BlingSlade
09-12-2013 02:00 PM
Jamia
08-28-2013 11:58 AM
americandollar
12-06-2006 01:00 AM
Bicepeak
06-14-2005 02:19 PM
Quick Reply: Dead mouse in defrost vent
