Should I Replace the Lumbar Foam or the Seat?
Hi MR_LUV! I would LUV it if you could recommend a solution for my problem. I have a 2008 Scion xD (manual) that I've owned since 2010. I'm not sure if the lumbar foam has worn out or if it was never there and I just didn't notice until now,
but there's a hard metal or plastic bump right where the center of my lower back sits.
Should I try to stuff more foam in there somehow (I looked into removing the stock seat cover and couldn't figure it out) or should I replace the seat? I don't really do anything aftermarket except the stereo,
so I have no idea where to start with a compatible seat. What kind of cost are we looking at? Can I install it myself? I have lots of tools, and I'm pretty handy.
Any advice would be very much appreciated!
Hi MR_LUV! I would LUV it if you could recommend a solution for my problem. I have a 2008 Scion xD (manual) that I've owned since 2010. I'm not sure if the lumbar foam has worn out or if it was never there and I just didn't notice until now, but there's a hard metal or plastic bump right where the center of my lower back sits. Should I try to stuff more foam in there somehow (I looked into removing the stock seat cover and couldn't figure it out) or should I replace the seat? I don't really do anything aftermarket except the stereo, so I have no idea where to start with a compatible seat. What kind of cost are we looking at?
Can I install it myself? I have lots of tools, and I'm pretty handy. Any advice would be very much appreciated!
I've own a lot of cars but, sorry I have no experience with car re-upholstery. On the surface, it would be unlikely your lumbar foam was missing. More than likely after 10 years it has worn down. You can try and re-upholster like in the video but, that is a lot of work.
My current 2015 RS9 tC2.5 has no problem with lumbar support. My old 99' Chrysler Town and Country minivan seats are in good condition because I keep a car seat cover over them but, has zero lumbar support so I bought a lumbar support cushion and that has
worked well for me:
You may want to check other cushions for size and thickness per your requirements. I would consider this Option before I consider re-upholstering or replacing your seats altogether.
MR_LUV
Looney
33
Jun 2, 2019 04:24 AM
Looney
Oct 16, 2017 02:08 AM
uber-xA-RS2
10
Jan 28, 2012 10:42 PM
