Scion xD ICE & Interior In-car entertainment and electronics...
xD - Remote Start - Manual
Old Dec 13, 2009 | 10:57 PM
trdcelica's Avatar
Default xD - Remote Start - Manual
Hey guys,
I just finished installing a manual remote starter (yes, the remote starter is made for a manual transmission) into my xD. The model I chose was the Ultra U1271m, commonly found on eBay. I am not sure how many people out there have done one of these on a manual but I figured I would post up some helpful hints for anyone out there who is looking for information (note: this is not a "how to remote start your manual xd write up", these are just some helpful notes I think may come in handy:
1. No immobilizer was required for my car. I am unsure if this is for all xDs however, mine did not require it and I wasted 40$ buying a Fortin immobilizer. Oh well, can't win them all.
2. Drop the steering wheel plastic shroud and you will see all of your ignition wires.
3. Brown wire in the driver's kick panel is one wire for the door locks (can't remember if it was the unlock or lock wire).
4. The other door unlock/lock wire, parking lights wire, break wire, and e-brake are found at the driver's side fuse box (if you even classify that behemoth of white plugs and such as a fuse box).
5. There are two wires at the clutch - yellow and black. Both of these wires see 12 volts when the clutch pedal is depressed. Tap into your remote starter "starter" wire with TWO wires and wire one wire into each clutch switch wire. DO NOT and I repeat DO NOT simply make a jumper wire at the clutch switch. Wiring it this way still forces any joe shmoe to still push the clutch pedal down to start the car.
6. I used the blue wire at fuel injector #4 for my tach signal.
7. Happy hunting :-)
#513412: 2008 SCION XD 4DR HATCHBACK WITH 1.8L ENGINE AND PIONEER® AUDIO SYSTEM
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery BLUE (+) RADIO HARNESS
Accesory GRAY (+) RADIO HARNESS
Ground WHITE/BLACK (-) RADIO HARNESS
Illumination GREEN (+) RADIO HARNESS
Dimmer GREEN (-) RADIO HARNESS
LF Speaker (+) PINK
THESE WIRES ALSO GO TO THE FRONT LEFT TWEETER
LF Speaker (-) VIOLET
RF Speaker (+) GRAY
THESE WIRES ALSO GO TO THE FRONT RIGHT TWEETER
RF Speaker (-) YELLOW
LR Speaker (+) BLACK
LR Speaker (-) YELLOW
RR Speaker (+) RED
RR Speaker (-) WHITE
Steering Cntrls YES
Speed Cntrl YES
Radio Security YES
Security
Battery YELLOW (+) IGNITION SWITCH HARNESS
THIS WIRE IS FUSED AT 25 AMPS
Ignition 1 PINK (+) IGNITION SWITCH HARNESS
Starter 1 BLACK (+) IGNITION SWITCH HARNESS
THERE ARE TWO BLACK WIRES - TEST TO BE SURE YOU HAVE THE CORRECT TWO WIRES AND THEN POWER THEM BOTH FOR REMOTE START.
All Door Trigger PINK (-) AT FUSE PANEL BEHIND DRIVERS SIDE OF DASH
TO AVOID DOMELIGHT DELAY USE INDIVIDUAL DOOR TRIGGERS AND DIODE ISOLATE EACH WIRE
Domelight Super PINK (-) AT FUSE PANEL BEHIND DRIVERS SIDE OF DASH
LF Latch RED (-) AT BODY CONTROL MODULE TO BEHIND FUSE PANEL BEHIND DRIVERS SIDE OF DASH
RF Latch GREEN (-) AT BODY CONTROL MODULE TO BEHIND FUSE PANEL BEHIND DRIVERS SIDE OF DASH
LR Latch BLUE (-) AT BODY CONTROL MODULE TO BEHIND FUSE PANEL BEHIND DRIVERS SIDE OF DASH
RR Latch BLUE (-) AT BODY CONTROL MODULE TO BEHIND FUSE PANEL BEHIND DRIVERS SIDE OF DASH
Trunk Trigger LIGHT BLUE (-) AT FUSE PANEL BEHIND DRIVERS SIDE OF DASH
Hood Trigger WHITE (-) AT SWITCH UNDER HOOD
Parking Lights GREEN (+) AT VEHICLE FUSEBOX
30 PIN PLUG PIN #29
Low Crr Pk Lights WHITE (-) AT VEHICLE HEADLIGHT SWITCH
Convenience
Headlights-Lo LIGHT BLUE (-) AT VEHICLE LIGHT SWITCH HARNESS
LF Pk Lt Bulb GREEN (+) AT FRONT LEFT PARKING LIGHT
RF Pk Lt Bulb GREEN (+) AT FRONT RIGHT PARKING LIGHT
LR Pk Lt Bulb GREEN (+) AT REAR LEFT PARKING LIGHT
RR Pk Lt Bulb GRAY (+) AT REAR RIGHT PARKING LIGHT
All Hazrd Lights BLACK (-) AT HAZARD LIGHT SWITCH HARNESS
LF Hazrd Bulb LIGHT GREEN (+) AT FRONT LEFT DIRECTIONAL LIGHT
RF Hazrd Bulb GREEN (+) AT FRONT RIGHT DIRECTIONAL LIGHT
LR Hazrd Bulb LIGHT GREEN (+) AT REAR LEFT DIRECTIONAL LIGHT
RR Hazrd Bulb YELLOW (+) AT REAR RIGHT DIRECTIONAL LIGHT
Wipers-Lo BLUE (-) AT VEHICLE WIPER SWITCH HARNESS
Wipers-Hi YELLOW (-) AT VEHICLE WIPER SWITCH HARNESS
Parking Brake YELLOW (-) AT VEHICLE FUSEBOX
16 PIN PLUG PIN #2
Trnk Release YELLOW (-) AT VEHICLE FUSEBOX UNDER DRIVER DASH
Remote Start
Ignition 2 GREEN (+) IGNITION SWITCH HARNESS
Accessory 1 WHITE (+) IGNITION SWITCH HARNESS
Anti-Theft Type UNIVERSAL IMMOBILIZER
Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense YELLOW (-) IGNITION SWITCH HARNESS
Tachometer RED (AC) AT ECM MODULE
Speed Sense VIOLET (AC) RADIO HARNESS
ALSO PIN AT SKID CONTROL ECU UNDER HOOD
30 PIN PLUG PIN #29
Low Crr. Pk Lights WHITE (-) AT VEHICLE HEADLIGHT SWITCH
Brake Lights GREEN (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Lights RED (+) AT VEHICLE FUSEBOX
30 PIN PLUG PIN #30
Horn LIGHT GREEN (-) AT FUSE PANEL BEHIND DRIVERS SIDE OF DASH
ALSO BLACK IN HARNESS AT STEERING COLUMN
Rear Defrost BLACK
Modules
WIRE LOCATION
Module 1 ECM MODULE - UNDER HOOD ON PASSENGER SIDE FIREWALL
Module 2 SKID CONTROL ECU - UNDER HOOD NEAR BRAKE BOOSTER
Module 3 MAIN BODY ECU - PART OF UNDER DASH FUSE/RELAY BOX ON DRIVER SIDE
Doorlocks/Windows
Power Unlock YELLOW (-) IN HARNESS IN DRIVERS KICKPANEL
TEST THIS WIRE WHILE TURNING THE KEY IN THE DRIVER DOOR CYINDER, REQUIRES A DOUBLE PULSE TO UNLOCK ALL DOORS.
PowerLock BROWN (-) IN HARNESS IN DRIVERS KICKPANEL
TEST THIS WIRE WHILE TURNING THE KEY IN THE DRIVER DOOR CYLINDER
Driver Mtr Unlock WHITE (REV) IN HARNESS IN DRIVER KICKPANEL
20 PIN PLUG PIN #10
Driver Mtr Lock LIGHT BLUE (REV) IN HARNESS IN DRIVER KICKPANEL
20 PIN PLUG PIN #20
Pas Mtr Unlock TAN (REV) IN HARNESS IN PASSENGER KICKPANEL
Pas Mtr Lock PINK (REV) IN HARNESS IN PASSNEGER KICKPANEL
LF Window Up RED (REV) AT POWER WINDOW SWITCH IN DRIVERS DOOR
LF Window Dn GREEN (REV) AT POWER WINDOW SWITCH IN DRIVERS DOOR
RF Window Up WHITE (REV) AT POWER WINDOW SWITCH IN DRIVERS DOOR
RF Window Dn PINK (REV) AT POWER WINDOW SWITCH IN DRIVERS DOOR
LR Window Up YELLOW (REV) AT POWER WINDOW SWITCH IN DRIVERS DOOR
LR Window Dn BLACK (REV) AT POWER WINDOW SWITCH IN DRIVERS DOOR
RR Window Up RED (REV) AT POWER WINDOW SWITCH IN DRIVERS DOOR
RR Window Dn GREEN (REV) AT POWER WINDOW SWITCH IN DRIVERS DOOR
Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
toyotaisme
Jan 10, 2015 10:24 PM
757_BRDFLY
Jan 9, 2015 12:29 PM
BV19869
Dec 11, 2014 06:05 PM
