2008-2010 [ZSP110]
Tire pressure Light
Old Mar 15, 2014 | 12:05 AM
TheWhiteSoph2008's Avatar
Default Tire pressure Light
Okay... I feel like an idiot, but, is there some sorta "trick", "method" to get that light off? I pressed the button net to the little glove compartment... nuttin.... ummm help? lol
Old Mar 15, 2014 | 02:25 AM
Lil_Deuce_tCoupe's Avatar
I have an 05 tC, wife has an 11 Camry. Same process for both, so I expect the xD should be the same.
Press and hold the button until the light goes off. Release, then press and hold it again until the light flashes 3 times. Then it will be reset.
Make sure your tire pressure is even all around before you reset too, or the light will come on again after a few miles.
You could also check the owner's manual for the process to verify, I believe it should be in there.
If the light does not go off after you press and hold the button initially, I believe that may be an indication of a bad sensor.
Old Mar 19, 2014 | 01:31 PM
brudsman22's Avatar
Can you post a pic of where this button is?
Old Mar 19, 2014 | 04:51 PM
FlintMica17's Avatar
There is a diagram showing it's location in your owners manual.
kingofthecrate
Jan 21, 2015 09:28 PM
JDMxB
23
Feb 26, 2004 06:16 AM
Strader
Oct 12, 2003 11:46 PM
