ABS light on.
k so the situation is that after putting my new wheels on (with no tpms sensors), my abs light has been on ever since. yesterday i went to adjust the coils and found my buddy had forgot to bolt my brake/abs lines back on.......
this is all in the span of a week. a visual check of the lines shows no damage (luckily). the fuse is good too. so am i missing something to make the light go off? maybe i need to find the sensor to see if its alright too? if so where is it at? thanks for any help guys.
Not an expert here, but you might try to clear the code with an OBDII reader. DTCs tend to stay on even after the problem is fixed unless you clear the code.
You could also just disconnect the battery for a couple minutes to clear the memory of your ECU, and if the ABS light is still on, look into the issue further because something might still be wrong.
2008ScionXbGold
11
Aug 15, 2016 10:50 PM
VCUBoy714
Scion tC 1G ICE & Interior
Jan 5, 2015 08:46 PM
umnitza
Dec 1, 2014 06:26 PM
