Tanabe or Tein?which are better springs?
i am trying to make the decision between these two.
or any other good brands you know thanks |
personally I'm fond of Tanabe's over Tein, however, it depends what you want out of your drop. do you want it slammed? cause tanabes wont slam your ride..teins are adjustable and will allow you to get lower than even DF's go. I have DF's installed and I think theyre amazing. I would just go with DF's and a new set of shocks/struts, if youre looking for a lower drop. as of now, theres only TRD shocks, which isnt a bad option.. That set up will only run you about 670 at most (trdsparks sells the shocks for cheaper) and tanabes arent expensive at all.
hope this helped! |
btw, PM me if youre interested in getting the Tanabes for discount as well
the tanabe df springs feel really nice, although im not sure how they compare to the s.techs.
NF's probably would clear any rubbing problems that DFs would cause. But yea, my friend's car doesn't have any problems with the DFs either. *shrug* |
Tanabe's FTMFW!!!
*edit*
i have the tanabe df210s, and they are pretty decent for the buck and the ride quality is nice on my tc
uhh...theres no rubbing at all with DF's...theres still fender gap *and thats panel gap...its WAYY off from the fender lining...* theres definitely no need to ever worry about rubbing with just springs...
nevermind, re'read the title. LOL.
How much fender gap did the DF springs gave you? like... one finger... two finger... two fist? lol curious
one finger rear, two fingers front
Tanabe DF is what I would good with.
that was in fact with stock wheels, no nice rims on my car :( haha. your wheels' width isn't vastly different from the stock set up. an inch and a half won't put you in any danger of rubbing.
OK, thanks for the info! Hmm... still chewing on whether I like the look of the NF's or DF's better, though...
and Kidd91, got the light kit off eBay, it's actually one of those Knight Rider scanners, but works as a Cylon scanner as well... But, It uses 8 standard incadescent bulbs, and not LEDs, mounted inside marker-light housings, mounted to a bar, ... I have a webpage on my Cylon mods here, goes into more detail, plus a youtube video of the scanner in operation, if you haven't seen it: http://troyfrey.com/scion TV Trivia Fact: The same production crew produced both of those original TV shows (Battlestar Galactica in the late 1970's and Knight Rider in early 1980's)... but BSG came first, and they actually re-used the Cylon scanner idea for the KITT car in Knight Rider - and not the other way around... |
mmmm that's why it looks familiar...its from KITT!! cool haha
Hey TRDxD - when you were giving me the finger, uh, I mean, the finger METHOD :P of measuring the wheel to fender gap, was that when holding your finger level, horizontally? So even with the DF's there's still a little vertical gap seen from the side of the car with the stock wheels/tires? From other photos I had been looking at, many of the tires looked like they were almost an inch up into the rear wells, behind the lip of the fender - and I don't really want any overlap like that... that would be too low for me.
I DO like the look of the two photos at the bottom of this page of the charcoal xD with NF210's on, looks like very little gap - those TRD wheels and tires are pretty much the same size as my 18's and 40 height tires... https://www.scionlife.com/forums/viewtopic.php?t=220665 |
On my car, holding my finger on the top middle of the tire (highest point) and keeping it horizontal, is how i measured it. as i said, with a bigger rim, theres a possibility they may tuck (overlap, as you've seen) but i do not think that it would be too drastic? however, I won't dispute what you've seen. could you show me the pictures you were takling about? otherwise, if you do like how the NF's look then take a couple days to think about it. look at as many pictures as possible, as the variety of rim/wheel combinations along with the springs will give you a true idea of how yours will sit, and what you will like.
well, I have 18" rims, but then of course I have lower-height 40 series tires on the wheels, so the overall outside diameter (or height from ground to top of tire) is pretty much the exact same measurement as the stock 16" wheels with 60 series tires on them... otherwise, it would throw the speedometer and odometer way off... so in my case that would make the diameter of my wheels irrelevant, because my tires are still the same diameter as stock tires - just wider and with a bigger donut-hole, lol!
Sorry, the link to the photos I was referring to was at the bottom of my last post, just to another thread right here in this xD forum... but I guess I worded my sentence wrong, I should have said "I DO like the look of the two photos of the charcoal gray xD in the last post on this page link: https://www.scionlife.com/forums/viewtopic.php?t=220665 it has the 18" TRD wheels with a similar height tire as mine, so the gap would be very similar on my car... |
