rims
If you're on stock suspension it should fit, probably full lock to lock. No idea how it would ride cause it also depends on what tires you get. I've seen a couple xDs with 19" wheels, and it either looks silly, or with the right body kit it doesn't look bad
i saw the size, but how the tire is made. if it has soft side walls and sticky tires, you will have a little bit of under steer if you take sharp corners, but overall road ride will be smooth. if you get an "eco" tire, which was manufactured for putting on high mileage, the hard rubber compound for the grip and sturdy side walls will cause for a slightly rougher ride. you also have to keep in mind our short wheels base, some bumps are expected to be felt regardless of your setup
