Replacing xB1 Front Door Lock Actuator Motor
Old 04-07-2009, 12:47 AM
George's Avatar
Default Replacing xB1 Front Door Lock Actuator Motor
Changing the lock motor is very easy and you only need a couple of screwdrivers to do it. The whole job took about 20 leisurely minutes, much less time than it took to write this up.
The procedure in the service manual is ludicrous, instructing the technician to remove the window and door latch!
Symptoms of a dead door lock motor:
  • 1. Door won't lock or unlock with the remote or with the inside lock switch. Clearance lights don't flash. No noise comes from the affected door.
    2. Other doors lock and unlock normally.
    3. If you lock the closed door manually, then push lock on the remote the other doors lock and the lights flash once normally.
    4. If you unlock the closed door manually, then push unlock on the remote the other doors unlock and the lights flash twice normally.
If you have these symptoms, your door lock position switches and associated electronics are working, but the door lock motor is dead. This is a sealed unit that cannot be repaired by normal efforts.
*If your symptoms are different you probably have a different problem, beyond the scope of this post.
Obtaining parts:
My local dealer (Frontier Toyota, Valencia CA) wanted $130 for the lock motor, including tax. I found the same Toyota OEM part on the Carson Toyota website (http://www.trademotion.com/partlocat...?siteid=214915)
and they delivered the part to my door the next day for $99 including tax and shipping. Shop around. Don't patronize dealers who overcharge their customers.
Tools required:
Normal #2 Phillips screwdriver
Stubby #2 Phillips screwdriver
Procedure:
Start with the window up and the door open.
  • 1. Using #2 Phillips screwdriver, remove screw in armrest grip and then remove the grip.
    2. Using #2 Phillips screwdriver, remove screw from door handle recess.
    3. On the forward edge of the door panel, there is a fastener that looks like a Phillips screw, but is an expansion fastener made of plastic. Use the Phillips screwdriver to turn it gently a bit and it will pop up, whereupon you can pull it out of the panel.
    4. Firmly pull on the top point of the triangular black plastic trim that conceals the mirror fasteners. It will pop out. Set it aside.
    5. Starting at the lower aft edge of the door, firmly pull the door panel away from the door. It will pop out. Pop all fasteners out across the bottom, the front edge, and the rear edge of the door.
    6. Lift the panel from the door.
    7. Disconnect the electrical connector from the window/lock switch. You have to depress the locking collar for the connector to disengage.
    8. Set the door panel aside.
    9. Starting at the lower aft corner, carefully peel the sheet plastic away from the adhesive between it and the metal. Don't tear the plastic! Peel it away to the upper aft edge of the door and about halfway across the bottom toward the forward edge of the door.
  • Fold the peeled corner up and out of the way and hold it in place with a bit of tape.
    10. Make sure that the door is unlocked.
    11. Disconnect the electrical connector from the lock motor. You have to depress the locking tab visible through the round hole in the door to remove the connector.
    12. Using the stubby Phillips screwdriver, remove the two screws that attach the lock motor to the lock mechanism. You have to do one of these by feel, but it isn't difficult Remove the lock motor.
    13. Install the new lock motor in the same position, making sure that the "basket" on the actuator arm traps the round plastic ball in the mechanism.
    14. Install the two Phillips screws to hold the lock motor in place. You have to do this by feel, but there is quite a bit of room and you just have to slide the lock motor back and forth a bit to find the holes. Tighten the screws snugly.
    15. Reinstall the lock motor connector.
    16. Fold the plastic sheet back down and re-stick it on the same adhesive from which it was removed.
    17. Reconnect the electrical harness to the lock/window switches on the door panel
    18. Reinstall the door panel by hooking its top edge to the top of the door. Be sure to guide the lock **** through its proper hole. Push the snap fasteners into their holes all around the perimeter of the door.
    19. Reinstall the plastic expansion fastener in the top front edge of the panel.
    20. Reinstall the Phillips screw in the door handle recess.
    21. Reinstall the door pull and tighten its Phillips screw.
    22. Reinstall the mirror trim by hooking its bottom edge and pushing it into place.
You're done. Test your handiwork.
____
George is offline
Old 07-23-2012, 01:57 AM
icemilkcoffee's Avatar
Thank you so much for this write-up.
I struggled with the steel rods for a good long time before I gave up and started searching Scionlife.
Once I read your write-up- I finished the job in 10 minutes!
_____
icemilkcoffee is offline
Old 08-11-2012, 07:04 AM
George's Avatar
I'm glad it was helpful! It only took three years for someone to need it!
George
George is offline
Old 08-16-2012, 04:56 AM
1TallOD's Avatar
Thanks for this info, I will be testing all the options mentioned above and see if my lock motor is dead or I have more problems.
I knew something was screwy when I had to resort to using the key or manually locking the drivers door.
My 04 xB only has a little over 50K miles, but when you use something everyday, things wear out!
Thanks again.
_____
1TallOD is offline
Old 08-17-2012, 05:49 PM
JIMXB's Avatar
Looks like a common problem, Wow... I have only 50K + my problem is intermittent with my lock. My motor must be starting to go
JIMXB is offline
Old 08-17-2012, 07:26 PM
Reactor's Avatar
You can buy actuator motor on ebay for about $7. Just a little more work to replace it instead of swapping the whole lock unit.
Reactor is offline
Old 07-01-2016, 07:31 AM
2005armyxb's Avatar
Originally Posted by George
Changing the lock motor is very easy and you only need a couple of screwdrivers to do it. The whole job took about 20 leisurely minutes, much less time than it took to write this up. The procedure in the service manual is ludicrous, instructing the technician to remove the window and door latch!
    If you have these symptoms, your door lock position switches and associated electronics are working, but the door lock motor is dead. This is a sealed unit that cannot be repaired by normal efforts. If your symptoms are different you probably have a different problem, beyond the scope of this post.
    Obtaining parts:
    My local dealer (Frontier Toyota, Valencia CA) wanted $130 for the lock motor, including tax. I found the same Toyota OEM part on the Carson Toyota website (Carson Toyota/Scion/Lexus Ultimate OEM Parts) and they delivered the part to my door the next day for $99 including tax and shipping. Shop around. Don't patronize dealers who overcharge their customers.
    Tools required:
    Procedure:
      I have the same problem, but all 4 doors. Do you think that this fix on each do would fix the problem?
      Thanks
      Dustin
      2005armyxb is offline
      Old 09-08-2016, 02:53 AM
      sammydad1's Avatar
      Default Me too
      Hi,
      I had to re-replace my driver's front door lock actuator. I think I replaced it about a year ago the hard way taking it all apart...
      Today I did it your way and it worked great !! I did have to pick up a stubby phillips screwdriver... One of the few tools I never aquired in earlier years.
      New item $9.99 off ebay went right in....
      Also, I didn't have to remove the mirror piece; the panel comes right off.
      Thanks for this tip !!
      sammydad1 is offline
      Old 10-03-2016, 03:22 AM
      Moderator
      Moderator
      DannoXYZ's Avatar
      Thanks for the write-up, this really helped! My wife just went through this procedure to replace the driver's door actuator on our 2004 xB. A couple of extra tips to help process go smoothly.
      5b. To save your finger strength, you can slide a flat screwdriver between door and panel and slide along edge until it bumps into clip, then pry. Slide screwdriver to next clip and pry. This works better on older cars with the cardboard door panels, as the hole around the clips can break if you're not careful. A set of door panel/ upholstery tools can really help. The 2-finger tool really helps with prying evenly on both sides of a clip to pull out the panel with minimal effort.
      10b. The actuator can be replaced with the door-mechanism in either the locked or unlocked position. The trick is to have BOTH arms on the actuator be parallel in the same position. The basket goes over the ball of the door mechanism and the finger goes between the two-finger prongs of the pushrod that moves the lock-tab up & down.
      14b. Helps to put the lower hidden-screw in first. Alight the basket and finger of the actuator with the mechanism. Press the tip of the stubby screwdriver over the lower screw's head to keep it from falling out and slide the actuator around in small circles. At some point, the screw's tip falls into the hole with a slight click you can feel, maybe even hear. Tighten lower screw halfway. Install upper screw and tighten. Go back and tighten lower screw.
      DannoXYZ is offline
      Old 10-05-2016, 02:11 AM
      finbar's Avatar
      Thanks George, your write up helped me get the job done.
      To help see inside the door I used a cell phone and face time with the computer.
      I also replaced the rear passenger lock actuator. It was more cramped but a similar procedure.
      A philips screw tip and a close quarters bit driver helped.
      finbar is offline
      Old 03-30-2017, 08:12 PM
      aphrodied's Avatar
      Thanks for the write up. It definitely helped me replace my actuator.
      I ran into an issue that I'm hoping someone else could shed some light on. Somewhere along the way, the arm on the actuator became stuck (I couldn't move it manually)(It moved normally originally). Once installed, the door locks and unlocks with power, but I still can't manually use the lock, from inside the car or outside with the key.
      I tested the actuator a few times during the install, so I suppose something could have happened then.
      I'm wondering if anyone knows of a way to unbind the arm, or do I need another actuator?
      Thanks,
      Dustin
      aphrodied is offline
      Old 07-27-2017, 03:22 AM
      BlackJackie's Avatar
      Default Thanks for the write up. Sharing photos to help out.
      https://drive.google.com/file/d/0BwA...ew?usp=sharing
      BlackJackie is offline
      Old 08-09-2017, 06:25 PM
      ebssea's Avatar
      George,
      I'm not a "car guy" my any stretch of the imagination (I can't even figure out how to change my oil) but I was convinced by your post that I could fix the driver's door actuator. I found one online for $20 from a company with a lifetime guarantee and guarantee fit, so figured I'd give it a shot.
      Pessimistic as I was about the supposed ease of the repair, I'm happy to say it only took me about 20 minutes and was not frustrating or difficult at all. Thanks a million for the detailed and well-thought-out tutorial here. It saved me around $200.
      ebssea is offline
      Old 08-26-2017, 03:55 PM
      MoJo187's Avatar
      8 years later this write up is still helping people, thanks.
      MoJo187 is offline
      Old 09-02-2017, 04:50 AM
      ebssea's Avatar
      One issue I did run into after replacing the actuator, however, is that the doors lock fine. But when I use my key in the driver's door to lock, it locks, but then I have to turn the key slightly to pull it out, which makes the door halfway unlock. Was it something I did in installing something crooked or what would cause this?
      ebssea is offline
      Old 11-20-2017, 06:52 PM
      Zach1984's Avatar
      I just replaced the driver door actuator in my 2005 xB and it was really easy. If you google part number REPS464904 you will find it for around $10 instead of the usual $80-$100 for the same part from different manufacturers, but I just installed it and it works fine (for now anyway). I was worried it would be some cheap knockoff junk that didn't fit but it looks exactly like the OEM part. Another thing to remember is the car wont lock with your key fob if the door is open. I screwed around with it for a half an hour trying to figure out why it would lock with the button on the armrest but the fob would only unlock it and not lock it.
      After I put it all back together and shut the door the fob started working again. I also never disconnected the window/lock connector because it was a pain to get it unplugged, I just rested the entire piece on a box so the wire going to the speaker wouldn't get ripped out
      ____
      Zach1984 is offline
      Old 02-12-2018, 03:21 PM
      Moderator
      Moderator
      DannoXYZ's Avatar
      I’m back with an update. This happened to my wife’s replacement actuator about about 15-months after the replacement. The manual tab/rod moves a rotary switch inside actuator that signals it to lock or unlock door.
      The switch shares an axle/pivot with the lock/unlock arm, but is independent. Either one can move independently. TEST these arms when you get your replacement. Some of them are bad right out of the box with insufficient grease. This can be detected by stiff movement of the manual switch. Over time it will get worse and seize like yours and mine did.
      We got a replacement actuator off eBay for $9 and it had no binding in the manual switch arm. Popped it in and everything’s back to normal!
      DannoXYZ is offline
      Old 02-27-2018, 02:21 AM
      Roughroadahead's Avatar
      Default Scion door actuator
      I don’t know if you will ever read this George but thanks. The year is now February 2018. Thanks for your posting. I could not figure it out either. I tried to find utube videos but found none that were useful. I used my iPhone and put it inside the door to take pics so I could find the screws. It worked. I followed your instructions line by line and finally did it. Thanks again!
      Roughroadahead is offline
      Old 04-18-2018, 04:04 PM
      retrocycler's Avatar
      Default thanks for brilliant and useful thread!
      I replaced both the front and rear driver side door actuators a couple months ago. Went smoothly thanks to this thread! Now the driver door actuator seems to have seized (already failed!). I'm glad for the most recent update, and will pursue advice about the "manual tab/rod"
      retrocycler is offline
      Old 11-06-2018, 12:06 AM
      boxxyMD's Avatar
      These pictures were extremely helpful when I was replacing my actuator over the weekend. Thanks so much! These pictures made it a 15 min job.
      boxxyMD is offline
      Quick Reply: Replacing xB1 Front Door Lock Actuator Motor
