Shark Fin Antenna install W/ PICS
Old 04-21-2009, 06:43 AM
A-snell's Avatar
Default Shark Fin Antenna install W/ PICS
just got a shark fin antenna from http://www.sharkfinantenna.com/
It took about a week to get it.
Here is the install..
1. Remove stock "stick" antenna..
2. Clean area around the base of antenna with rubbing alcohol and 3m prep solvent. I used Turtle Wax liquid clay bar and rubbing alcohol after..
3. Attach the coiled cord to the antenna base using the supplied hardware. NOTE: use the washer that is supplied.
4. bend the antenna base all the way forward for clearance.
5. Place fin antenna into position on car, align it and use painter's tape to mark it's position on ALL sides..
6.remove backing on adhesive foam tape and GENTLY place the antenna back into position.
7. Once you are happy with the alignment, press the antenna down and hold it firmly for 1 minute. (the adhesive is pressure sensitive)
8. Remove tape, step back and enjoy your new Shark Fin Antenna..
A-snell is offline
Old 04-21-2009, 07:13 AM
A-snell's Avatar
here are a few more pics of the car with the fin on...
A-snell is offline
Old 04-21-2009, 09:31 AM
BBN-Boys's Avatar
awesome job! it makes it look that much cleaner.
BBN-Boys is offline
Old 04-21-2009, 10:22 AM
ellisinseoul's Avatar
i like too....but can't decide if it's worth it......
ellisinseoul is offline
Old 04-21-2009, 10:31 AM
Yo_Br0ski's Avatar
looks good
Yo_Br0ski is offline
Old 04-21-2009, 02:39 PM
pyroman131's Avatar
It definitely looks really cool and I have contemplated about integrating that with my Silver xB, but I don't want to spend $70 on it. If they offered a Scion Life discount like Mobilehid does, then I'd be a little bit more interested.
All-in-all, great DIY. It looks really clean and makes a VERY sleek look to the car.
pyroman131 is offline
Old 04-21-2009, 06:24 PM
AAG
DeepSouth Scions
AAG's Avatar
Looks good! I personally like the stock antenna because it's so thin and less visible.
AAG is offline
Old 04-21-2009, 06:27 PM
Iceman04503's Avatar
Looks good but man that is a big antenna.
Iceman04503 is offline
Old 04-21-2009, 11:12 PM
A-snell's Avatar
I think it was worth it.. received tons of compliments already... it changes the whole "attitude" of the car..
A-snell is offline
Old 04-22-2009, 01:30 AM
SHOCXB's Avatar
Looks good but not sure if I want to spend the $$.
SHOCXB is offline
Old 04-22-2009, 04:50 AM
pyroman131's Avatar
$40 and I'd buy it. $70 is a different story.
Old 04-22-2009, 09:28 PM
A-snell's Avatar
I wasn't to upset spending the money for the Fin.. especially since it is color matched to the car..
A-snell is offline
Old 04-22-2009, 09:37 PM
pyroman131's Avatar
True, I mean that is definitely one good thing about is getting a perfect match. I wouldn't consider buying something like this from eBay. I guess it bothers me because it's so small. If it was spoiler sized, or came with a $20 bill when shipped to you, then I'd buy it.
Old 04-23-2009, 02:55 AM
that is true...you take something to the bodyshop and they will charge you a minimum of 150!
Old 04-23-2009, 03:22 AM
A-snell's Avatar
just received an email form Visual Garage inc. (The company that sells the antenna) They want to use the pics I sent them for their photo gallery. they should be up by mid May.
A-snell is offline
Old 04-23-2009, 03:27 AM
captainlaziness's Avatar
Any change in radio reception?
captainlaziness is offline
Old 04-23-2009, 04:20 AM
CIONIDE's Avatar
In major metropolitan areas my reception is fine, but in suburban outlying areas the FM reception is not quite as good as the stock antenna.
CIONIDE is offline
Old 04-23-2009, 04:45 AM
DarkBox8's Avatar
Just ordered one of these puppies! Can't wait to get it...well worth the money IMO
DarkBox8 is offline
Old 04-23-2009, 05:14 AM
Rogue_Dragon's Avatar
Looks just like I thought it would.....Awesome!!!!! I cant wait to see it in person at the bbq this weekend. Nice install write up.
Rogue_Dragon is offline
Old 04-23-2009, 07:23 AM
layedoutxa's Avatar
It looks good, I need the antenna element that's inside it, I want to tuck it under my headliner, since my antenna is gone completely.. Any idea where to get something flat or small like that?
layedoutxa is offline
Quick Reply: Shark Fin Antenna install W/ PICS
