2004 Scion xB overheating
Old 10-22-2018, 03:33 AM
duffman1997's Avatar
Default 2004 Scion xB overheating
My xB is overheating it doesn’t do it all the time I drove it all day and the light started blinking I turned it off and came back and drove home it was fine it’s happened twice so far coolant from the reservoir has bubbled out a couple of times.
I just did a Burpee to the system and new Thermostat and the fan is kicking on. The hose going to the engine sucks in when it get hot I put a pic of what it does. I just filled the Radiator and now it low the reservoir is full.
What do I do?
duffman1997 is offline
Old 10-23-2018, 10:58 PM
RichBinAZ's Avatar
That hose will be your problem, it should not collapse. Have you or any other previous owner ever changed the hoses on the car?
If not it sounds like it's time to change out all the large hoses and any of the small ones you can get access to. Then refill with toyota coolant and you should be good for another 6 years for coolant and 12 years for hoses.
Might want to check the thermostat and see if it is in the right way up.
I did a PPT years ago on it if this is something you want to tackle yourself
https://postimg.cc/gallery/39qrk00xy/
RichBinAZ is offline
Old 10-27-2018, 04:09 PM
Super Moderator
SuperMod
MileHightC's Avatar
Excellent info and write-up, I'm going to see if we can get this added to the 'Tech' section...PM sent.
MileHightC is offline
Old 10-29-2018, 03:34 PM
RichBinAZ's Avatar
E-mail sent with the full PPT file and also a ppt of the aux input fix.
Link to my car maintenance page on youtube also. Has the fix for when you assemble the drum brakes on the rear wrong and a few other things. Some XB related too.
Old 10-29-2018, 11:27 PM
Super Moderator
SuperMod
MileHightC's Avatar
Received and replied...thank you very much, Rich!
Nikki
Scion xD Drivetrain & Power
03-31-2024 01:22 PM
BlingSlade
16
08-10-2021 10:17 PM
KraXxuS
13
12-25-2019 07:31 PM
LowerLevelMan
06-22-2009 11:32 PM
kronicillusionz
03-05-2007 11:25 PM
Quick Reply: 2004 Scion xB overheating
