Scion tC 2G ICE & Interior In-car entertainment and electronics...
Power wire for Heated Leather Seats..
Old 02-18-2019, 09:15 PM
mrchillz's Avatar
Default Power wire for Heated Leather Seats..
Hi, I just bought a 2015 Scion tC and the heated seats don't work.
I found the fuses for them in the drivers side kick panel but the wire after the fuses must of got pulled out somehow and is not hooked to anything.
Can someone please tell me where this wire should go?
mrchillz is offline
Old 02-19-2019, 08:22 PM
62Fender's Avatar
I'd call the person or place you bought it from and tell them you weren't advised that some of your electrical wiring is compromised. Ask if they'll cover the cost of repair.
If you don't get any relief from the seller and you wish to work on it yourself, you'll need to find out whether the heated seats are factory or aftermarket. Then you'll (likely) need the factory and or aftermarket wiring diagram(s).
In the interim, you might want to insulate that bare lug so it doesn't short its circuit and or other(s).
62Fender is offline
Old 02-20-2019, 05:00 PM
Big_Jim's Avatar
^^ agree with contacting the seller.
I didnt realize heated seats were an option until I looked them up.
Looking at the picture you posted, I'd say those heaters are aftermarket. OEM seat heaters use 10A fuses located in positions 19 and 21 of the under dash fuse panel.
I'd recommend starting out by checking for voltage at the fuse. Pull the switches and trace the wires out from there. The power should go from the source to under the seat, and the switch should be fed from under the seat.
Big_Jim is offline
Old 05-05-2019, 09:17 PM
bigrock07's Avatar
Is there a thread for adding heated seats? I think that would be pretty cool/hot (pun_intended)
bigrock07 is offline
Harro10
22
04-30-2021 08:05 PM
Nate
01-04-2017 07:03 PM
robbiej
Scion xD ICE & Interior
07-17-2015 06:21 PM
reelknead1
12-29-2011 03:21 AM
crazydrummer7
12-08-2011 09:32 PM
Quick Reply: Power wire for Heated Leather Seats..
