First gen xB spoiler mounting info/parts list
Old Yesterday | 11:17 PM
Low_Kei's Avatar
Default First gen xB spoiler mounting info/parts list
So I’m going to do the xB community a solid. Since life has gotten in the way of me making the OEM spoiler install kits, I am going to supply you all with the part numbers so you can source your own.
Parts list is as follow
x2 EPMD rubber well nuts with with brass M6-1.0 insert
x2 M6-1.0x25 Metric yes flange bolts grade 10
Those are for the upper bolts
The lower plastic grommets that the spoiler pins insert to are from a different Toyota vehicle
Toyota Part Part No.: 08150-52867
As for the instruction and templates, I am working on getting those again or you can contact your local Toyota dealership
The lower grommets are about 2mm smaller in outer diameter size which is why when I sold my kits I had to make a correction to the install instructions. Basically find drill bits that will match the outer diameter of the upper well lower part and the outer diameter of the lower grommets. I will see if I still have the specs on that.
Unrighteous
Mar 28, 2026 05:00 PM
Low_Kei
50
Jun 9, 2025 10:31 AM
W0X0F
Jul 31, 2020 06:14 AM
sn0w
Scion tC 1G Aero & Exterior
Jan 18, 2011 01:37 AM
Jdmport
11
Aug 1, 2007 03:17 PM
