Angel Eyes / Halo Install 2 (Umnitza)
looking to do this when i find a spare set of lights to mod up. wanna do this and spray tint the amber reflector and maybe figure a way to color match the chrome eyebrow area to see what that looks like under the lens cause i dont like the way vinyl overlays look...
i wanna wire mine to a separet switch or piggyback the parking light wires though cause i like the parking light and wanna keep it.
Great job. That's an excellent detailed write-up, xIxAMxHOLLYWOODx! I also drilled into my housing to run the wires through. It's much cleaner that way but I have to admit I was pretty scared during the drilling process!
I'll have to agree with davedavetC on applying extra silicone to the power inverter (especially if you are attaching it beneath the high beams), all connectors, and an extra bead around the entire housing. I have the Umnitza ones and thought everything was good to go until I found out otherwise the first time it rained. Luckily I disconnected them quickly and it didn't short out the inverters. I just let them dry out, siliconed everything and moved the inverters to a safer location. No problems or condensation now for the past year (knock on wood).
i'll add a note to add extra silicone around the ballast box and on any exposed connections for safety. But the way I see it, the ballast under the headlight wont have a very good chance of getting wet. Unless you've removed your inner fender wells... the whole thing is pretty safe from getting wet. but I guess extra silicone couldnt hurt.
as for around the housing itself, the headlight has more than enough sealant around the edges, and its not going anywhere. (unless you removed it for some unknown reason) I havent had any problems with condensation and we've gone through a wide range of weather patters here in So Cal this week. 100+ temps during the day, 60 and below at night, rain/fog in the morning, etc... and no condensation in the headlight...
Originally Posted by Jehoo
Just in case the factory sealant went to the clear glass housing, what can I use to wipe it away?
