Brake Pad Change (Front Only)
another good way to get the piston to get down is to put the inside brake pad back in the caliper and use the c-clamp or a big set of vice grips (locking plyers) to hold down to push the piston back in, make sure you do it slowly tho, like mentioned before.
hey so really... you should actually loosen the bleeder valve from behind when pushing the piston back in. i heard you could damage ur ABS pump if you do it the other way... personally i just do wht every1 else does,
if your getting noise it's from lack of brake paste or using old clips/backing plate. that autozone brake paste is crap..
also, you ahould perform a brake fluid service every 2yrs. brake fluid is extremly hydroscopic.
another thing,, we have floating calipers, lube the guide pins.
another thing, don't not open the bleeder to do a pad/rotor service, usless you have a PRESSURIZED bleeder hooked up or plan on doing a brake fluid service. you will get air in the lines,,, (remember we are surrounded by 14:7psi of air pressure) the abs pump will by fine.
this is coming from a certfied tech ;)
Originally Posted by a_german_named_hans
question. I only have a 3 inch c clamp. Is that good enough or should i get a 6 inch c clam?
I'm about to order some brake pads of sparks. The grease I could pick up at any auto shop right? Is it called anything in particular or does anyone recommend a specific grease?
