tC Tech and DIY Info for the Scion tC
Cell Phone Mute Function
Old Feb 8, 2007 | 02:41 PM
Scionizer07's Avatar
You don't need a photo, its a connector on the back of the radio, there is only 2, one is full, one has an open pin, thats it.
Old Feb 17, 2007 | 08:30 AM
aen's Avatar
aen
the 07 radio has alot of open ones
Old Jun 22, 2007 | 06:17 PM
jumong69's Avatar
Default Re: Cell Phone Mute Function on Stock 2005 Radio xB/xA/tC
Originally Posted by douglaing
I put a new Motorola Bluetooth hands free kit for my cell phone in my XB and wanted to mute the radio when the phone was in use and or when it rang. All hands free kits wired and wireless have a wire to mute a radio if supported.
My stock pioneer radio did not have this function documented, well I took the radio apart and found that the un-used pin on the smaller connector was the mute function.
I was not able to find a proper metal socket/pin to put into the connector so I took a #14 wire stripped off about 1/4 inch folded it back against itself to make a 1/8" doubled up end and forced it into the blank hole to make contact with the radio's pin then zip tied it to the wire next so it would not work it's way out. I then connected the end of this wire to the mute wire from the cell phone hands free kit and it works great.
My radio is the single CD stock pioneer that is used in the 2005 XB XA & TC.
I do not know if this works in the 6 cd version but if it has the same missing wire in the smaller connector it probably would. To test just ground that pin on the radio's connector if the radio mutes then comes back when removed you have it.
This is not documented by Toyota and I am not responsible if it kills your radio but it worked for me. I have been using it for about a month now, I use my XB for work and am on the phone on and off all day long.
Thank you for your post. I am thinking about installing Moto ihf-850 or 1000 to my car also. The only problem is that it does not have themute wire on the back of t1804 stereo. I would love to try out your method but I would also want to see the picture of how you did it. I have attached the back side of the stereo. Would you please tell me which connector I should plug it into? Is it the C4? If not, please tell me which letter. Thank you in advance.
Old Jun 28, 2007 | 05:02 PM
jumong69's Avatar
UPDATE: The C4 is the place where you have to use to mute function. I wonder what blue and yellow wires are for?? maybe for the speaker?
Old Nov 29, 2007 | 10:49 PM
Chichum's Avatar
Anyone know which plug it is for the 2008? I found that one and grounded it and it didn't work. I wanted to put the +12 to it but I wasn't sure what it is so no need to fry it.....
Old May 20, 2008 | 03:31 AM
sparcshinobi's Avatar
anyone tried this on their 08 Premium radio?
Old Jan 5, 2009 | 11:25 AM
Eltaco's Avatar
BUMP
Any new info on this? I want to swap my Parrot BT from my Ram to my tC and need to find out if there is a mute function on the "non premium" CD MP3 player.
Old Oct 28, 2009 | 11:01 PM
Hazelsxb's Avatar
thanks for the info I think i will use it on my xb
Old Nov 11, 2009 | 03:14 AM
TOMMYPHAM's Avatar
i will do it on my radio tomorow ,,,
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
rain7905643
Jun 13, 2018 05:29 AM
Sgtfluffy16
Sep 30, 2015 01:42 PM
