tC Tech and DIY Info for the Scion tC
Fog Light Rewiring
Old Sep 25, 2010 | 05:19 PM
  #141
2FA5T4U's Avatar
Thanks for the great DIY. Finished in 5 min.
Best option in my opinion is: grey + green
Old Oct 26, 2010 | 09:33 PM
  #142
cookie16v's Avatar
Read the whole thread and want to ask a couple of questions, does this work with Xb2 and does anyone know how to bypass the the high beams as well?
Old Jan 1, 2011 | 01:42 PM
  #143
ugman9401's Avatar
My wires match your photo diagram, however I have no power when I remove the white (your gray) wire. The pink wire on the other end of the connection is the same pink wire that is in the engine bay that is connected to the fog wording harness.. Does it matter that I'm running hid's 3000k fogs? Or the fact that they are grill lights not jdm corners?
Old Jan 11, 2011 | 08:48 AM
  #144
Mauipinoyracer's Avatar
soooo with this method on where you put the grey wire to the green wire can the fog light turns on and off if i want to? with the switch? cuz i dnt want them to be on all the times i juz want it on when ever i feel want to turn it on
Old Jan 11, 2011 | 09:41 AM
  #145
ugman9401's Avatar
Guess I should update.. My fogs run great.. I have my gray wire tied to my parking light fuse and a switch installed (not oem) work great!
Old Jan 30, 2011 | 11:27 AM
  #146
HyPnOtIk's Avatar
Too bad none of the pics work anymore. Also say i dont want them on, will the switch inside the car still turn them off with this wiring mod done?
Old Jan 30, 2011 | 09:12 PM
  #147
AcidDrop's Avatar
^yes if you mod the wiring to turn on while the car is off or with the parking lights you can still turn them on and off with the switch
Old Jan 30, 2011 | 11:00 PM
  #148
HyPnOtIk's Avatar
Cool. I plan on wiring it to turn on with the parking lights. Now if only the pics on the first page were still there so i could see exactly how he did it.
Old Jan 31, 2011 | 06:18 AM
  #149
AcidDrop's Avatar
i'll try to take pics of mine tomorrow, i did the mod for the parking lights. but i remember getting a flat head and prying up on the clip that's in the middle of the plug and pushing out the grey wire with a pick, then you jam the grey wire's metal pin over the green wire in the same slot of the green wire and wrap it with a bunch of electrical tape. after press the clip down, it will take some force and your done.
Old Jan 31, 2011 | 06:47 AM
  #150
HyPnOtIk's Avatar
Sounds simple enough. Its the plug inside the car behind the switch right?
Old Jan 31, 2011 | 08:49 PM
  #151
AcidDrop's Avatar
yeah it's the plug that is behind the switch that has the relay to it as well
Old Feb 2, 2011 | 05:41 AM
  #152
pena1128's Avatar
Can the pics be posted again plz..
Old Mar 10, 2011 | 10:56 PM
  #153
RustystC3208's Avatar
i will second that notion pleasseeeee
Old Mar 10, 2011 | 11:07 PM
  #154
ugman9401's Avatar
I deleted the whole pigtail.. The pinkish wire on the stock wired harness that you'd connect your aftermarked pigtail to, I took that wire out of the connector and connected it to mu parking fuse with a breaker switch.. If I leave the switch on at all times it will shut off when I turn car off and open door. Or I can flip the switch off.. All ya need is a breaker switch and about 9" of wire.. It gets rid of that bulky relay and the other 2' of wires and the switch that comes with the light kit..
Old May 4, 2011 | 09:18 PM
  #155
Chef_Reggie's Avatar
Need pictures ASAP .. Not sure how to get the pin out
Old May 4, 2011 | 10:16 PM
  #156
Jk I got it .. Pretty simple .. Kinda hard without pictures tho
Old Jul 4, 2011 | 08:03 AM
  #157
misfits138's Avatar
great write up, i have a quick question i want to use the daytime running lights mod for my fog lights but im not sure where to put the gray wire since the pictures dont work. could someone help please?
Old Mar 29, 2012 | 09:21 PM
  #158
jjp735i's Avatar
Default Fog lights
I have an 05 tc and just went out to do this mode and I do not have a gray wire. I've looked and looked and there is no gray wire. Anyone else have this problem or have an 05 they did this mode to. I would like mine to come on with the parking lights.
Thanks, jjp
Old Sep 4, 2012 | 10:10 PM
  #159
user 7208230's Avatar
Just in case anyone needs this with photos, I know I did. I found it on ClubSciontC: http://clubsciontc.com/forums/diy-in...ersible-30214/
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
LzeroKI
Scion tC 1G Aero & Exterior
Feb 10, 2015 07:28 PM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
carid
Jan 8, 2015 11:33 AM
tc_Jake
Dec 31, 2014 01:45 AM
