LED Swap (05-06 HVAC w/Circuit MOD)
Ok have completed the mod. All Leds on left side and clock are great!, also the last two on the right side are fine as well. Yet D311 & D312 are not working. I had them working upon orginal completion but now they aren't. Tried changing LED's and also verified all soldering points. Any sugguestions? I will post a pic of the right side tonight if this helps.
well i have mine partially done. the LEDs for the tach aren't lighting up for some reason so i have to re open that and find out whats going on with that. I also notice that it seems the right 3rd portion of the center console screen isn't lighting up so i have to check into that as well.
Make sure you have the jumpers and resistors attached to the correct LEDs JQ. It sounds to me like you forgot the wire jumper between the right side of the 2nd and 3rd LED down on the right side. This provides the ground for the top two LEDs on the right since cutting that trace disconnects those two. Check to make sure you added that jumper.
It is hard to tell by the pic, but I think there may be two issues. The first wont cause them not to work, but should be changed so everything matches. The resistor you have connected to D313 (the one bent at a 90 degree angle and soldered to the longer resistor lead) appears to be a 330 Ohm. This should be a 680 Ohm. The only 330s are the ones that replace the three surface mount resistors you have to swap out. The other three are 680's.
Now again, it is hard to see from there , but it looks like you have the resistor that is connected to D316 attached on the upper lead of the resistor at the top of the picture (this should be a 330 ohm, the one you swapped for the surface mount). This should be attached to the bottom leg of that resistor looking at it from the viewpoint of the picture. A couple more things to check out.
Now I have to go and cut the the housing so it fits.
THANKS!!
I had a quick question, i was looking around online for a place to be able to buy these resistors, was able to find 2 site but each one wanted a mini buy of like 300. Has anyone found a site that has the resistos with a normal buying of like 6 (i want a few spares incase)? Or any tips as to where i can find, if not i will try to hit up radio shack this week. Thanks
thats hot man, you are the ____! I am moving into a new place, and i am getting married next month, so one day engifineer, one day i will send my gauges off to you! LOL when you got married didja ever feel like you were never goin to be able to buy another car part ever again.....lol
Did this mod today... I used fine wrapping wire, but it doesn't spare you anything
The resistors are still too big for the button housings to fit over, so you still need to cut. But like engifineer said, it's really soft plastic and easy to do (and more importantly, the cutting part is hard to screw up lol)
My all-white console looks terrific now! Another happy customer.
The resistors are still too big for the button housings to fit over, so you still need to cut. But like engifineer said, it's really soft plastic and easy to do (and more importantly, the cutting part is hard to screw up lol)My all-white console looks terrific now! Another happy customer.
I guess it depends on the resistors you get. enginfineer gets the good SMT ones. Ridiculous Shack doesn't have those, so they're kinda big.
I suppose you COULD wire the resistors so they're out of the button housings' way, but that'd just increase your trace length. But yeah, ehh, it works.
I may start doing these locally here in NJ or as mail-swaps. I found a junkyard that had 2 sets of HVAC control units and he gave 'em to me for $75 each - both intact.
I suppose I could do the work and cross ship them to people willing to pay to have the work done.
Of course if I did that, i'd have to toss engifineer a percentage of each sale
It'd only be fair. We wouldn't have this fix if it wasn't for him.
