LED Swap (Guages / HVAC)
i juss got my gauge cluster and center console done by Karl....guy is amazing man...thanxx.....i did everything white except the middle gauge(speedometer) dat one i did green.....it looks awsome ill have sum pics up sooon
hmm.... you should've hit me up back in july when i was in waikiki for vacation..
also... the brightness thing... cameras can lie... but leds are still and can be really, really bright.
as long as the color is even and it looks good... it shouldn't matter...
Originally Posted by kronicillusionz
Ive been looking at this thread for a year and I still havent found the confidence to do it =P
i am interested in replacing the led's in my gauges to blue from www.mouser.com, but there are far too many different kinds of led with 500 other names... i need help finding one that should be used on tc
I wanted to thank "panasoanic", "engifineer", and "WhiteBlazer01" for all their tutorial help on this mod.
Easy enough to do once you get going. The gauge cluster comes apart very easily and there is more than enough advice on this subject to guide you.
Like anything I suggest taking your time and remembering how things came apart to put them back together properly again. My two mistakes were not pushing the odometer pins all the way into the socket so I had to take my cluster back apart and diagnose that issue(an easy 5 minute job). I still need to figure out why my 3 fan LED's don't work but reading the soldering posts that the two sides may have connected may be the problem.
Originally Posted by aandf1978
I just had my LEDs swapped but now my CEL is on, does anyone know why?? Anyone had this before??
- Paul
- Paul
Just pm'd you back. As mentioned, this happens from time to time if the car was driven without the gauges in. You could reset the ECU, but it should go out on its own fairly quickly.
Engifineer.... I need help. I'm currently doing the gauge cluster blue. I want to keep things like the red line RED and the top of the temp gauge. Temp gauge doesn't matter so much... but as far as leaving the red line on the tach red... which LEDs do I not replace?
I'm in Gurnee (by Six Flags). I did my gauge cluster two weekends ago. Took no more than 2 hours. I could do it for you. Contact me via PM if you want to figure a time and date. This weekend is NOT good for me though. I'll send you pics of my blue gauges later tonight. I don't have any spare LEDs though.
