tC Tech and DIY Info for the Scion tC
Mirror Turn Signal Change
Old Sep 19, 2007 | 11:11 PM
  #141
Amoxaphobic's Avatar
Ok, there is no resistor in the light, and the voltage is about 4-5 volts. This is kind of an average because it's hard to tell the voltage with a multi meter while the lights are blinking. LoL.
Either way, I know it's not 12v.
Old Sep 20, 2007 | 12:03 AM
  #142
SquallLHeart's Avatar
yeah.. definitely... def... definitely not 12V..
Old Sep 20, 2007 | 02:54 AM
  #143
fishingexpert87's Avatar
i just put the puddle lamps that i had under the car and used them for the turning side mirrors, its very bright and beautiful
Old Oct 2, 2007 | 04:49 AM
  #144
GreenFlash's Avatar
The TC lokks Insane. How come you said the second time around I used 5mm LEDs? And also where did you buy all of you Headlights turn signals lights from?
Old Oct 2, 2007 | 12:22 PM
  #145
I think the first time he used 3mm. Second time was 5mm... a little bigger, and they are supposed to be brighter. But IMO, in the turn signals, they are just about equal.
You can get the turn signals for the headlights at autozone, pepboys, ebay, etc... just got to look around
Old Oct 2, 2007 | 09:40 PM
  #146
GreenFlash's Avatar
Cool, thanks. I will probably give it a go this weekend.
Old Nov 26, 2007 | 08:10 AM
  #147
fponce2007's Avatar
i plan to but some blue led's on the mirror side markers and i keep reading that it is legal and it is not legel...any one now if it be ok in cali???
Old Nov 26, 2007 | 08:28 AM
  #148
GammaTNT's Avatar
blue lights outside of the car are illegal ,
side markers are suppose to be orange only.
When i saw cops around, i don't even dare to use white turn signals.
And U will get pull over in CA faster than any other states.
Old Nov 26, 2007 | 08:42 AM
  #149
fponce2007's Avatar
oh..ok......id like to put blue iv seen it in some tc's but wasn't sure about it...wat about white?
Old Nov 27, 2007 | 01:32 AM
  #150
Yeah, blue is def illegal. Especially if they are blinking. White is not completely legal, but it's not something that most cops are going to say anything about - unless of course you are in a town with bored cops, or CA.
The law (in most places) states that any light shining from the front of your car will be white or yellow. And light shining from the rear will be red or yellow, with the exception of the license plate light which is required to be white. This is how people get away with white blinkers - technically it's legal.
Other than that, no light may be visible from the car. Many people will argue that no light BULB may be visible but the "glow" is allowed. However, this is really up to the cops discretion. At the very least, the cops could give you a ticket for being a distraction on the road.
Old Dec 6, 2007 | 02:08 AM
  #151
StreetStarsTc's Avatar
hey
if water gets into the turn signals after install
does that screw everything up as far as harnesses?
or do i just re-solder and do it again
i didn't silicone it well enough the first time =/
Old Dec 6, 2007 | 05:30 AM
  #152
ehh.. things get wet... oops... dry it off and re-seal... hopefully there's no water damage.
Old Dec 7, 2007 | 05:01 AM
  #153
If the thing was soaked in water and you used the blinkers then the possibility of messing something up exists. However, the first thing to go would most likely be a fuse.
Trung is right, dry it off and try again. You should be good to go.
Old Dec 7, 2007 | 05:27 AM
  #154
okay so basically just check the fuse box?
so i guess i'll do that and check the bulbs
Old Dec 12, 2007 | 08:42 PM
  #155
audioandy's Avatar
nice write up.
Old Nov 3, 2008 | 01:31 AM
  #156
nrgwar's Avatar
how much will this set me back to do ?
Old Nov 3, 2008 | 09:38 PM
  #157
leds are like $.80-1 each? you need 4 of them.. plus a tube of silicone or other glue.. and tools..
Old Nov 3, 2008 | 10:04 PM
  #158
costs like 10 bucks IF you have the tools
i did mine TWO times yet they keep burning out, am i not putting enough silicone? or should i use a circuit board? donde?
Old Jan 25, 2010 | 06:28 PM
  #159
Aphex13's Avatar
I know it's an old thread, but I'm about to do this, and I was wondering if there was ever a solution to the led's burning out... I think I'm going to put three in instead of two, maybe that will help.
Old Feb 8, 2010 | 08:59 AM
  #160
CLT-tc's Avatar
^ x2 i want to do this did anyone get theirs to work long term?
