tC Tech and DIY Info for the Scion tC
A-Pillar 3 Gauge Pod Install (Creative Compacts)
Old Jun 19, 2006 | 02:36 AM
  #61
jwaggz82's Avatar
word
Old Jun 19, 2006 | 02:37 AM
  #62
miamibusta69's Avatar
then il buy the one from ebay
  #63
zer0's Avatar
You will not be disappointed. :D
Old Sep 4, 2006 | 11:50 PM
  #64
Spoolin's Avatar
awesome write up
Old Sep 20, 2006 | 07:55 AM
  #65
Eppopipe's Avatar
OhioScions
has anybody installed a air/fuel and oil pressure gauge in the tc
and how does everybody elses cc pod look
mine was hell to get lined up after i ran the wires.
Old Sep 20, 2006 | 08:00 AM
  #66
WeDriveScions's Avatar
Lots of people running a UEGO or similiar guage, plus all the other setups and such...
I decided against running it, as the pods didn't line up well enough for me and don't want cops to see lit guages in my car... Good setup for cheap though.
Old Sep 20, 2006 | 10:37 AM
  #67
vaccaro's Avatar
what will the cops due if they see lit gauges.. they see mine all the time. You can not get pulled over for having lit gauges.
Old Sep 20, 2006 | 10:40 AM
  #68
vaccaro's Avatar
Default gauges
I have A/F which i ran into a problem with. You have to drill in to your header. if you get the narrow band. Next time i will purchase the right type of gauge so i can tap right off my ecu. I have voltage and water temp. as well.
Old Sep 20, 2006 | 11:12 AM
  #69
BrEaK_AwaY's Avatar
if u get a a/f ratio, get a wide band by aem like WDS was saying. one of my gauges installed are oil pressure, and to install this properly, you need an oil block adaptor (i got mine from greddy i believe)
Old Sep 20, 2006 | 11:19 AM
  #70
vaccaro's Avatar
yeah i tried to hook my a/f through my ecu. But i was told i would have to tap from the exhaust manifold or the headers. Whats the worst that could happen if i am leaking in either of those area's?
Old Sep 20, 2006 | 11:27 AM
  #71
vaccaro's Avatar
if there are minimal problems that could accure. i will drill and tap it myself.
Old Sep 20, 2006 | 12:06 PM
  #72
BrEaK_AwaY's Avatar
ur header and exhaust manifold is the same thing. a header is an exhaust manifold.
some wideband a/f ratio sensors have their own sensors (i think aem's is like this) to where u would have to tap into the spipe (not the header) with a new bung. I would suggest u let a performance show / muffler shop / or someone who can weld a bung into the pipe.
Old Sep 20, 2006 | 12:08 PM
  #73
vaccaro's Avatar
i am a welder myself.. but i guess i could always let some one else do it. what are the side effects of a leaking header?
Old Sep 20, 2006 | 12:25 PM
  #74
vaccaro's Avatar
what i am asking is if i drill a hole. and i some how do not do a good job welding.. what are my side effects going to be. Will the car still run ok? will it even start?
Old Sep 20, 2006 | 12:46 PM
  #75
BrEaK_AwaY's Avatar
it depends on where u drill and where u are leaking. if you have a leak before your wide band o2 sensor, your going to have problems, and you will probably run lean because the sensor isnt detecting as much exhaust flow, so in return, you wouldnt feed as much fuel (because the ecu assumes that car isnt taking in much air either), there for running lean.
Old Sep 20, 2006 | 12:47 PM
  #76
vaccaro's Avatar
if i drill after?
Old Sep 20, 2006 | 01:56 PM
  #77
BrEaK_AwaY's Avatar
u should be fine, because i think u have to drill inthe spipe anyway
Old Sep 20, 2006 | 07:33 PM
  #78
LoL... they won't do much if they see guages in my car, but when they start looking elsewhere, as a result of noticing the lit guages... Umm... could not be the best situation...
I may run them and wire them to a switch, so I can turn them on/off... to see them when I need to, and for shows... but keep it quiet inside most of the time... (I like quiet and sleeper)
Old Sep 21, 2006 | 06:13 AM
  #79
Eppopipe's Avatar
OhioScions
ok so i have a issue....
how do i hook up these gauges
a diy would be very very apprciated
i have all autometer procomp gauges.
a/f ratio
volt
oil pressure
how do i wire these in????
where
what to tap
do i need to buy more stuff
do i need to goto a shop and spend some money? (hope not)
help!
Old Sep 21, 2006 | 06:57 AM
  #80
I comprimised and am going to get my CC A-Pillar pod color matched, as the color is WAY off, and pop in in. I have the autometer CF Pyro/CF Boost and AEM UEGO Wideband for it... just going to run the lights of the guages to a switch so I can shut them off for staying sleeper and hassle free night driving.
Your Autometer A/F procomp guage is worthless (at it is narrowband and tells you NOTHING effective), return it and get something else in it's place, if you go Turbo or such, invest in an AEM UEGO or other "Wideband A/F" controller in it's place... as they tell you acurately what your A/F is at any point in time... but, are pricey
Volt is really easy and just follow the instructions and tap it into 12v supply wire of the deck or cig lighter, or if you really want to, on the ECU...
the oil pressure is a little tougher and clicking features/tech will have a how to from Kaeon on oil pressure tapping suggestions...
-WDS
