tC Tech and DIY Info for the Scion tC
Pulley Install (ZPI, Lightweight Crank)
Old Apr 18, 2009 | 10:23 PM
  #121
mengsta's Avatar
Cool, you will definitely need the impact set for many future things.
Old Apr 19, 2009 | 02:05 AM
  #122
kuo34's Avatar
cpomakita.com has refurbed makita corded and cordless impact wrenches (as well as all kinds of cool tools) for cheap. Just an FYI for those out there that are shying away from projects requiring heavy tools. Thanks for the input mengsta.
Old Apr 19, 2009 | 10:18 PM
  #123
kuo34's Avatar
On a side note, the torque specs for the crank pulley per the "2006 Scion tC Repair Manual (RM1104U)" under 14-18/Engine Mechanical diagram is 133 ft*lbs. I've seen 110 and 150 mentioned and found that in the diagram while doing my homework for the mod.
Old Apr 23, 2009 | 01:33 AM
  #124
kuo34's Avatar
Did this today. Took about an hour with the marjority of the time getting the belt back in place because it slipped out. Had the impact wrench do the heavy loosening. The belt was off a little bit on the water pulley and had the tension bolt locked out tight, so I put the transmission in neutral and used my breaker bar to turn the crank by hand to thread the belt back on the pulley. Thanks for the how to and all the additional input folks!
Old Sep 12, 2009 | 07:30 PM
  #125
alienvictim's Avatar
Originally Posted by ZPIracing
these engines are internally balanced...installing this is no diffrent that installing a lighten flywheel. We would not sell it if we thought it would damage it.
you are wrong
Old Sep 13, 2009 | 02:14 AM
  #126
rhythmnsmoke's Avatar
Music City Scions
OMG...seriously...this thread
Old Oct 4, 2009 | 04:21 AM
  #127
Empir3's Avatar
bump!
I am removing my crank pulley. The car is in gear but the crank is still spinning when I try to loosen the bolt. The car is automatic. How do I keep the crank from spinning?
Old Oct 4, 2009 | 04:31 AM
  #128
CDogbert's Avatar
Originally Posted by Empir3
bump!
Inertia, aka use an air ratchet.
This is incorrect. The destroyed bearings in my old block can attest to this.
Old Oct 4, 2009 | 04:32 AM
  #129
DJ08tC's Avatar
I am pretty sure you have to use an impact gun or you will never be able to get it off
Old Jun 9, 2010 | 06:40 PM
  #130
kc2hje's Avatar
thank you for the write up Q for the mods can this posting also be labeled for belt change outs?
As this weekend I could not find a way to release tension on the belt until I read this how to
Old Aug 22, 2011 | 06:33 PM
  #131
SB08tc's Avatar
Default WHAT!!!!?
Originally Posted by mr_lore
Awesome! now maybe I'll get off my lazy ___ and do mine thats been lying in the trunk of my tc for a month now.
I have you beat. I have had mine in a box for three years. LOL, i have finally got some time to get mine done.
Old Jan 10, 2012 | 03:39 PM
  #132
uhsentc's Avatar
what is the torque setting we need to set to put nut back in?
Old Jan 10, 2012 | 04:04 PM
  #133
Sgtfluffy16's Avatar
very hard to torque a crank pulley bolt just put it on with an impact and some loctite.
Old Jan 10, 2012 | 04:05 PM
  #134
Default For Sale Lightened Crank Pulley
PS if anyone is looking to buy a lighten crank pulley Im selling mine.. here is the link
https://www.scionlife.com/forums/sho...r+crank+pulley
Old Aug 27, 2013 | 03:49 AM
  #135
jcraff3's Avatar
how come i can only find faqs about crank pulley alone, are the other ones just not sold? cuz i have a feeling changing them all lightweight would do that much more
what if i went smaller or bigger in order to replace all pulleys with lightweight and just got a new belt, could that benefit also?
SuBSiN
Mar 13, 2015 04:02 AM
Frustratez
Feb 26, 2015 04:03 PM
NonStopTuning
Jan 20, 2015 05:20 AM
TheTripleC
Jan 4, 2015 06:46 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
