tC Tech and DIY Info for the Scion tC
Shifter Cable Bushing Install (NST)
Old 08-30-2006, 09:06 PM
WeDriveScions's Avatar
Default Shifter Cable Bushing Install (NST)
Here's the DEAL!
The install of the bushings requires you to remove the stock air box and push the tubing out of the way, or in my case, remove the CAI tube that connects to the throttle body... Both of these are very easy to do, and only require the disconnect of the MAF sensor, plus the removal of a few bolts....
Once you get the Intake Clear, you should Be good to go!
Disclaimer - This install guide is only based on my experience and for your basic information on how to perform this installation yourself. Please take every safety precaution neccesary. I will not be held liabel for any damages this can cause to your engine if done improperly, or if following these directions, as I am only a tuner like yourself. Please perform at your own risk.
-With that out of the way-
[table:8b1290b743][mrow:8b1290b743]Tools Needed[mcol:8b1290b743]Flashlight
Snap Ring Pliers
See Here - http://www.bobstools.net/Store/media/49200clp1x11x1.jpg
Socket Set and Screwdriver to remove airbox or CAI
For Better Longevity and Smoother Performance - Wheel Bearing Grease
Thats about it
[mrow:8b1290b743]Step 1 -
Locate the Bushings in the open area... (Look for the big metal counterweight)[mcol:8b1290b743][mrow:8b1290b743]Step 2 - Locate First Bushing Here.
[mcol:8b1290b743][mrow:8b1290b743]Step 3 - Locate Both Bushings[mcol:8b1290b743][mrow:8b1290b743]Step 4 - Remove the Pin from the first bushing
[mcol:8b1290b743][mrow:8b1290b743]Step 5 - Remove the Washer from the first bushing
[mcol:8b1290b743][mrow:8b1290b743]Step 6 - Lift the cable and bushing off the rod and push the crappy rubber bushing out with your fingers (don't let it fall)
[mcol:8b1290b743][mrow:8b1290b743]Step 7 - That's all three parts, you want to keep the pin and washer for re-install
[mcol:8b1290b743][mrow:8b1290b743]Step 8 - Place the new bushing in the hole left there.
[mcol:8b1290b743][mrow:8b1290b743]Step 9 - Put the bushing and cable back on the rod (You may want to add a small bit of wheel bearing grease on the outside of the rod for smoother and lasting throws)
[mcol:8b1290b743][mrow:8b1290b743]Step 10 - Locate the second bushing and remove the pin and washer
[mcol:8b1290b743][mrow:8b1290b743]Step 11 - Lift the cable and bushing off the rod and push the bushing out... it's really soft...
[mcol:8b1290b743][mrow:8b1290b743]Step 12 - Put the new bushing in and place the cable and bushing back on the rod... (you may have to wiggle a bit) (You may want to add a small bit of wheel bearing grease on the outside of the rod for smoother and lasting throws)
[mcol:8b1290b743][mrow:8b1290b743]Step 13 - Now you are ready for reassembly, by first attaching the snap ring, then putting the washer back and and recliping the original retainer clip (Those steps to come soon)
[mcol:8b1290b743][mrow:8b1290b743]Step 14 - The old stuff
[mcol:8b1290b743][mrow:8b1290b743]Step 15 - What you need to place back on.
[mcol:8b1290b743]][mrow:8b1290b743]Step 16 - Snap Ring Pliers are a must to get those snap rings on the new bushings
[mcol:8b1290b743]][mrow:8b1290b743]Step 17 - Snap that Ring on!
[mcol:8b1290b743]][mrow:8b1290b743]Step 18 - I had to pull the bushing off to get enough room to snap the second ring on... (Then just place it back on the rod)
[mcol:8b1290b743]][mrow:8b1290b743]Step 19 - Reinstall the washer and reinstall the original retainer clip!
[mcol:8b1290b743]][mrow:8b1290b743]Step 20 - Both Washers and Clips back on and you're good to go! Just reinstall the CAI or your stock box and feel the difference!
[mcol:8b1290b743]
[/table:8b1290b743]
If I forget something, please let me know, and I'll do my best to get it in... Suggestions to improve are welcome!
-WDS
WeDriveScions is offline
Old 08-30-2006, 09:52 PM
ALL Done.... ENJOY!
Old 08-30-2006, 10:00 PM
InfideL's Avatar
o nice you made the DIY gj mad props to you!
honestly you dont need it but it makes people feel easier by having some confirmation
InfideL is offline
Old 08-30-2006, 10:05 PM
It helps people know exactly what is included in an install...
I agree that it's pretty straightforward, but some individuals really want to see the whole picture before jumping in
I also believe that NST will be including this online on their page and possibly shipped with them...for a good reference...
Old 08-30-2006, 10:07 PM
Nick06tC's Avatar
awesome. Guess I need to steal the wifes lunch money and buy a set.
NST FTW!!
Nick06tC is offline
Old 08-30-2006, 10:09 PM
Nick06tC's Avatar
Its a perfect write up. it would cost them 4 pieces of paper, so it would be easy and cheap to throw in the mail with them. Better safe than sorry. I honestly had no clue where the busings were located. Granted i am sure it would only take 5 minutes to find. This just made life alot easier.
Nick06tC is offline
Old 08-30-2006, 10:39 PM
Spect2K3's Avatar
Wow, thats one of the best writeups that i've ever seen - no matter how simple it may be. NST should give you some commission because i'm buying them b/c of this writeup. Hopefully that didn't take too long to do. Thanks for the writeup!
Quick Q - you just reconnect the MAF sensor when you are done and thats the end of that or is there some sort of reconfiguration necessary for the sensor?
Spect2K3 is offline
Old 08-30-2006, 10:46 PM
No neccesary recalibration... disconnecting it doesn't remove any settings... Just make sure to connect it back up again well.
Old 08-30-2006, 11:15 PM
sIcKsCiOnS
sci-on's Avatar
you helped a lot man..great write up..i salute you..
sci-on is offline
Old 08-31-2006, 01:45 AM
Thanks... I also did an install DIY of the Pulleys as well... Both of these are available in the tech section now as well.
Old 08-31-2006, 03:12 AM
Garage1217's Avatar
Killer write up man! But do not forget to add a small smear of wheel bearing grease inside the bushing were it rides on the shift linkage. Will help shift smoother and also keep the investment lasting for years and years to come with flawless service!
Garage1217 is offline
Old 08-31-2006, 05:37 AM
^ Thanks.... Updated and Added.
-WDS
Old 08-31-2006, 06:44 PM
Guest
Guest
Posts: n/a
Nicely done! :D
Old 09-01-2006, 04:34 PM
MysTiKchRis's Avatar
Nice
MysTiKchRis is offline
Old 09-02-2006, 12:02 AM
Off Topic Split.
Keep it on topic to the NST Install...
You can do this install without taking off the CAI, but in the attempt to make it as clean and simple for others, removing the CAI and/or Stock Intake piping gives you much more room to work with ease...
Others have done the install without... but, I suggest you take advantage of the available room that comes with a quick removal of piping.
Old 09-02-2006, 12:06 AM
zer0's Avatar
There is plenty of room, with CAI on. Good luck supercharged people with trying to put these on. Idk how your fitting those snap ring pliers down in there.
zer0 is offline
Old 09-02-2006, 12:07 AM
chrischoi's Avatar
well how come they dont include directions.
chrischoi is offline
Old 09-02-2006, 12:10 AM
zer0's Avatar
Also a little quicker method, for popping out the OEM rubber pieces, is to take a screw driver and pry it out. It helps.
zer0 is offline
Old 09-02-2006, 12:11 AM
The NST Shifter Bushings are Stainless Steel and run 22 dollars...
For Ordering information, please see www.nonstoptuning.com
or also, you can contact the owner through AIM at "NSTonAIM"
Old 09-02-2006, 03:11 AM
jwaggz82's Avatar
how hard would it be w/ the s/c in there but the intake tube off?
jwaggz82 is offline
Quick Reply: Shifter Cable Bushing Install (NST)
