Shifter Cable / Cage Bushing Install (CorSport)
Tools Needed:
For Shifter Cable Bushings - Your Hands For Shifter Base Bushings - 12mm socket Cor Sport Suggests removing some of the stock air intake for an easier install time. Please check this DIY in order to remove air intake box. https://www.scionlife.com/forums/viewtopic.php?t=123625 Are you ready? Good! https://www.scionlife.com/tech/image...hings_tc/1.JPG Get all your parts together and bring them outside. https://www.scionlife.com/tech/image...hings_tc/2.JPG Locate your shifter cables (Under air box) Notice the pin and washer on top. https://www.scionlife.com/tech/image...hings_tc/3.JPG Remove pin and washer then remove the bushing using HAND force only! https://www.scionlife.com/tech/image...hings_tc/4.JPG Old junk on top New hotness on bottom, Looks a lot better doesn’t it :) https://www.scionlife.com/tech/image...hings_tc/5.JPG Now with your shifter linkage empty. https://www.scionlife.com/tech/image...hings_tc/6.JPG Place the solid metal bushing in place. Place the bushing so the groove for the "e" clip is facing up. https://www.scionlife.com/tech/image...hings_tc/7.JPG Use "e" clip to secure. https://www.scionlife.com/tech/image...hings_tc/8.JPG Then top it off with the pin. Pat yourself on the back because you are done with that part! https://www.scionlife.com/tech/image...hings_tc/9.JPG It’s time to get to your shifter base. https://www.scionlife.com/tech/images/tcover/4.JPG https://www.scionlife.com/tech/images/tcover/5.JPG Pop off your shifters trim Next Step is Optional: https://www.scionlife.com/tech/images/tcover/9.JPG Remove the two screws at the top that connects the center console to the dash. Then remove the two 10mm bolts hidden under the carpet in the center console armrest. Don't forget to unplug the cig lighter. You can now remove the center console for more room to work. https://www.scionlife.com/tech/image...ings_tc/10.JPG Remove the (4) 12mm bolts https://www.scionlife.com/tech/image...ings_tc/11.JPG Bolts removed https://www.scionlife.com/tech/image...ings_tc/12.JPG Then remove the metal stopper from the rubber bushing. https://www.scionlife.com/tech/image...ings_tc/13.JPG Remove the rubber bushing using hand force only. https://www.scionlife.com/tech/image...ings_tc/14.JPG Grab your metal bushings; https://www.scionlife.com/tech/image...ings_tc/15.JPG Install the bottom bushing first https://www.scionlife.com/tech/image...ings_tc/16.JPG Then install the top bushing, replace bolts and tighten up. Your good to go. Review: The products quality is good I’m told there will be an option for red or blue anodized pieces in the future. The install was easy and pretty straightforward. The only problem was that there were no instructions included. I’m told there will be a set made and sent out with future kits. Upon finishing I noticed my shifter felt stiffer, it was a bit harder to get into gear but felt nice and tight. I personally think I will like it a lot. Unfortunately (as some of you may know) my car is not drivable right now, so I was unable to give it a good test drive. I will continue this review once the car is back on its feet. Big Thanks to Tai from www.corsportusa.com for help with this review |
Thanks for the incredible review, we truly appreciate it over here at CorSport! ;)
Anyway, so everyone knows the base bushings are on backorder until early to mid october. Have no fear though, the cable bushings are the better of the two mods (IMO) and still available! Tai CorSport |
The best review of the bushings right here. Nice work.
add this baby to tech!
thanks for the writeup kaeon |
i'd warn about dropping stuff into the framing under the shifter, YOU WILL NEVER SEE IT AGAIN. I lost two screws down there and i found one that didnt make it all the way in. Yall have been warned!!!!
Bump.
in the 4th pic there are 2 new bushing but in the 6th it looks like you only installed 1 am i missing somthing
Double post. Sorry.
Thanks Kaeon!! |
Bump.
The new anodized aluminum versions (in a dark gunmetal/bronze type color) will be available in a couple days! Tai CorSport |
What is the purpose of the base bushings...How do that actually enhance shifting?
any reviews of the shifter base bushings for those who have em in? (kaeon was saying his car isn't driveable)
The picture shows 8 shifter base bushings...why do we need 8? |
4 corners -- 1 top and 1 bottom per corner = 8 bushings for the base.
Ah, I didn't realize that they were on the front as well, but makes sense...duh! Thanks
New hard anodized Gunmetal Aluminum bushings in stock and ready for shipping. (still have a few brass ones for those that may want them gold) -- put in notes when you order which you want.
http://www.corsportusa.com/store/cat...shings&x=0&y=0 THanks for looking, Tai CorSPort |
Bump
Installed the shifter base bushings today from corsport. Great customer service and quality products. I find the cable bushings to be much more effective than the base bushings. I don't feel a big difference with the base bushings like I did with the cable bushings, but nevertheless, everything feels nice and tight. For the price, you cant go wrong. Thanks corsport!
hate ta burst your bub, but you forgot to install the oem washers that went between the bushing and the pin. check out the propa install https://www.scionlife.com/forums/vie...ushing+install
| All times are GMT. The time now is 01:18 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
